Question about Sony Playstation 3 (PS3) Console
My playstion 3 has no display or sound after disconnection hdmi connection and going back to rca connection, worked fine until then any ideas, it comes on but no sound or video thanks jamie
  • 3 Answers
U will have restart ur ps3 mine has done this before i just restart and it automatically switches back to rca it does this when hdmi is plugged in also this is all from my 60gb im sure its the same all the way around
Posted on Apr 24, 2010
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Check your settings,both bios and display,for the display priority.Either the settings has been set to inbuilt display and thus cant display on external monitors or the external monitors have been disconnected in bios settings
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
When I'm told the system was not turned off correctly press ok then the screen stays blank
You corrupted your settings. Turn on the Ps3 let it power cycle, once you get to the blank screen hold down the power button until it beeps 3 times (about 25 secs) Your ps3 will shut off( note: if you have HDMI only, plug in your RCA connections as this will reset your ps3 display to analog) once you are back at xmb, plug in your HDMI and go to display settings and select HDMI. Always let your PS3 do its thing before shutting it down, its equivalent to unplugging your computer instead of logging off correctly.
Jul 06, 2012 | Sony Playstation 3 (PS3) Console
Pioneer vsx521 stopped recognising hdmi connection from computer
Press the Audio Parameter button (Looks like an x) then scroll up until you see 'HDMI AMP' and hit over to the left or right so it shows 'HDMI THRU' the HDMI will redo the handshake and you should have sound.
Mar 12, 2017 | Pioneer Audio Players & Recorders
I connected my receiver to my hdmi dvd player and ps3. I am able to get a video connection however there is no audio. I have connected evrything via HDMI. Also, I ran all the troubleshoots mentioned in the...
You are not alone...Sometimes HDMI connections fail to provide Audio on some equipment ...
You should carry Audio separately with a RCA cable..
OR without HDMI ,you can make the following connections:
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your DVD
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
RECEIVER corresponding your RCA or Optic connection...
There you go..Both DVD sound and Video are on the
Receiver..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 29, 2011 | Onkyo TX-SR505 Receiver
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
Ps3 works on hdmi but not on rca jacks ???
Sometimes its a pain to re hook up the cords if you are stuck in HD mode and tryin to go back to Regular or Vise Versa, power off the ps3 press and hold the power button for 3 seconds. that will switch the video card back to default settings.
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
Can not get HDMI to work on PLAYSTION 3 on my Philips 42' Plasma
I had the same thing with my PS3 on a samsung 40". Try pressing the power button down on the PS3 for 5 secs or more, until it beeps (Not sure if it's one beep or a series of). I think this is how you reset the system and it should automatically recognise and reset the resolution size to HD on you're screen. Hope this helps,
Andy.
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
No sound or display
go back to your friend or another with a hdmi tv then connect the ps3... when connected go into the menu for display and switch output from hdmi to scart it should then work on your tv
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
104 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
