Tv has it's own channels set up, and i can't find and input
  • yamilyo Mar 24, 2008
    ho w can i get a new remote for my tv
  • 59 Answers
On your remote push "Menu" push the "enter" button on the remote, then go to "Setup" push the "enter" button on the remote, then go to "Cable" if you have cable or dish OR go to "Air" if you have an antenna, then push "enter " on the remote again. This may take a few mins to set up your channels.
Posted on Mar 23, 2008
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
I need to know how to set up my tv's input I have no button on the tv to change the input but If anyone knows how I can get to it pleas help
There are two flip up doors on your TV at the front. Open the doors and look for INPUT or use the channel button and go all the way down to the lowest channel and go one or two channels past that channel and you should see the INPUT with your Wii connected to it. Be sure to have the Wii on while searching...
Mar 09, 2013 | Televison & Video
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
I have a 42" Hannspree TV. What channel do I put
h;
your DVD player has an output of Audio and Video, and at the back of your TV has and input A/V
you have to connect a RCA cable to this inputs, your RCA must have 3 connectors yellow for video,red for left channel audio white for right channel audio,
then set your TV to AV1 if connect it to AV input 1,there are two AV input at the back,and also SVideo input,
you have to set it by pressing INPUT or TV on remote or button of your TV.
Sep 03, 2011 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
I have a lcd 37" polaroid tv / dvd combo I use to have it hooked up to Direct TV and now wanted to just get the free channels with an antenna. Eveytime I scan for channels it doesn't find any. Do u think...
go into the set up menu and set the signal input to AIR, the rescan for channels. Directv should have been going into a sat box then into a different input than the Ant jack so make sure your on the right input
Jul 16, 2009 | Polaroid Televison & Video
External input
I'm not overly familiar with your brand, but generally there are 2 ways to get to the AV input.
1) Use the TV/Video button on the remote (if there is one)
2) Channel up or down from the last channel at the high or low end. In other words: channel down from channel 2 may bring you to the AV input.
Hope this helps,
Dan
Sep 23, 2008 | Orion Televison & Video
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
