Question about Brother MFC 5100c InkJet Printer
My printer has stop printing on my brother mfc 5100c
First the machine ask for a replacement of yellow ink and now is will not print print at all. also I keep get an error 41 message.
  • 4,041 Answers
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Posted on Apr 25, 2010
Trying to use the copier and it won't work
Hi there go in printer setting & select the B/W printout. I hope its will start work. If still he asking for replacing the yellow ink then you have to replaced. Because some printer have a single sensor for all color. If he find one of them is out or no ink then he stop working. Thanks & waiting for your feedback.
Apr 07, 2010 | Brother MFC 5100c InkJet Printer
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
It says machine error 41 on my brother MFC 5100C machine
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Jan 10, 2010 | Brother MFC 5100c InkJet Printer
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
I change replace all ink in my brother mfc-5100c after that I receive this message: "Machine error 41, unplug the machine call brother". Please,What can I do to fix it? I rely on you for any assitance.
Machine Error 41means the printhead is bad. It's a fairly easy repair on that model, but an expensive part and requires replacing all four ink cartridges at the same time. New machines are so much smaller and cheaper that it may not be worth it. There are also some setting that must be changed in Service Mode to match the machine to the characteristics of the new head.
If you're still interested, look for Brother part number LK0935001.
Jun 01, 2009 | Brother MFC 5100c InkJet Printer
MFC-5100C won't print all colors...
Hello 4wards,
Try getting one of the expensive cartridges, some printers don't use all of the cheap inks, because it prints out only the acceptable colors. Get a better Ink Cartridge and it should be fine.
Hope this Helped - NeWeVoLuTioN
Sep 04, 2008 | Brother MFC 5100c InkJet Printer
Brother MFC 5100C making white line in printing
The printhead is probably clogged. You may be able to clean it, by removing the mechanism and soaking the actaul printhead in a solution of white vinegard or you may have to replace the printhead. A web search may result in instructions on how to remove the head. Prinheads appear to still be available via Ebay and others. They run about $60-70 and if you have a bit of tech abilities, replacment should be relatively easy to do yourself. Not sure about finding a repair center that will do it for you or what the associated cost would be..
Feb 12, 2008 | Brother MFC 5100c InkJet Printer
Brother MFC 5100c InkJet Printer Logo
107 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
