Question about Motorola Mobility RAZR V3i Cellular Phone
The camera on my motorola razor phone is locked
When ever I try to open the camera on my razor a notice pops up saying "Unable to open camera". I have never noticed this before. What do I do?
  • 45 Answers
Try changing your firmware at a phone shop or on the net
Posted on Mar 25, 2008
SOURCE:
I have a motorola razor and every time i get a picture message it says it is unable to download? How do I fix this?
The problem with Razor cells phone is that the use old service connects or it is to large of a file to be able to download because they have limits.
Try resizing the image then sending it Also try sending it in a different format
May 10, 2011 | Motorola Mobility RAZR V3
UNABLE TO OPEN LOCK.
my mobile no. 8826637327,my handset motorokr z6. In my mobile airtel sim unresistered sim showing.
Jul 12, 2010 | Motorola Mobility RAZR V3
Unable to charge
Um, you might need to either buy a new charger, or its your phone.
May 26, 2009 | Motorola Mobility RAZR V3
Unable to download
Check a cable connectors clean,restore a phone to factory settings.go to Menu/settings/initial setup/master reset/enter 6 zero ok. and then try to down load,should be ok.
Mar 31, 2009 | T-Mobile Motorola Razor V3 Custom Cell...
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
NEW RAZOR PHONE NOT WORKING
Your Phone Is Locked To Another Network Than The One Your Trying To Use.
You Need To Get It Unlocked Or Use The Network The Phone Is Locked Too.
Good Luck :)
Regards,
Sophie.
Mar 09, 2008 | Motorola Mobility RAZR V3
Unable to charge the razor
there may be a short in the wire or in the plug. try wiggling it around a little bit and see if you can get a connection
Jan 19, 2008 | Motorola Mobility RAZR V3
Motorola razor
You have a foulty camera, exchange for a different one before warranty expires!!!
Nov 18, 2007 | Motorola Mobility RAZR V3
Location setting
If your cell is carrier locked, and carries custom carrier firmware (software for the phone) then you probably don't have that option available to you. Flashing a custom firmware is the only way to get access to locked items (not for the beginner phone tinkerer.)
Nov 08, 2007 | Motorola Mobility RAZR V3
Camera says unable to open camera
Get it warrantied cause any attempt to fix this by you will void the warranty. For everyone else, Remove the faceplate, on the top right you'll see a cable going from your screen to the camera. lift the brown part of the connection and remove the cable. CAREFUL, if this gets damaged you will have to buy a new camera!! After this I would completely remove the camera from it's housing and reseat it.
Nov 22, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
90 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
