Question about Water Heaters
When i but the battery in the charger the orange and the green light comes on and i left it in for a long time and the battery was only charged a little bit whats wrong
    New Friend:
  • 81 Answers
This has happened to me. The transformer in the charger is dead.
you can test the charger by plugging it in and using a multimeter to test for current.
if you get nothing, it is dead.
You will need to get a new charger pack.
Posted on Apr 27, 2010
Hot water heater keeps shutting off.
This sounds like a circuit board has a component that may be heating up and failing. When the unit is unplugged power is shut off to the circuit board, which will allow the component to cool down and start to work again. If this is the case then the component will fail completely at some time.
Dec 22, 2015 | Water Water Heaters
Why does the low battery light comes on shuts the heater down, but the battery has full charge? The model is 2300-700 this heater runs around 30 secons then stops?
Is this the European Fix ya? Nice to know the Mfr to know what is being fixed? If the low BATT light comes on I don't see why unless you just bought the battery you believe it is fully charged and is this a Battery Powered Tankless Pilot Light?
Sep 09, 2014 | Water Heaters
The light below the green or orange button with 3 lines down is on what does this mean, I also need a manual which didn't come with my machine
Question posted under water heaters, but no brand or model number is given.
Question asks for product manual. And asks for interpretation of error code.
1) Look on side of water heater for machine information, and then add a comment and include all possible detail for best result, including brand and model number, and approximate age of machine, and whether machine is gas or electric powered.
Adding a comment with specific information will tell expert what answer to give, or expert might not be expert in your product and will suggest that new question be re-posted at fixya for another expert.
2) To find a product manual on your own, Google search model number of machine, and add the specific words to search parameter: instruction .pdf
For example search for: Rheem Pro40NE2 instruction .pdf
Sep 05, 2011 | Water Heaters
Problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
water will always find its own level and take the path of least resistance. if your hot water tank inlet is higher than the swamp cooler this may be your problem. you can try a line resrtiction at the cooler or a twelve volt rv pump with a battery and solar charger and an on off switch.know someone with this set up and it seems to work well.
Nov 28, 2009 | Water Heaters
The direct ignition switch will not light the burner, We have replaced the switch, but it still does not light.
Have you checked for 12 volts DC getting to spark module ? If it's just the 2 wires going to spark module, Red and green, check for 12 volts at the red wire.
If it has the 9 wires on 2 connectors, check for 12 volts at Brown and Orange. If no 12 volts there, then you'll have to go back to switch and check there for 12 volts in and out when switch in on position. Let me know what you find.
Sep 02, 2009 | RTO Atwood Water Heater - 6 Gal LP
How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Apr 01, 2009 | Whirlpool Water Heaters
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Water Heaters Logo
24 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
