HP A6600f desktop, loud beep 18 secs off 10 sec, cylce repeats
HP A6600f desktop, when turned on it there is a high pitch noise for 18 seconds then off for 10 secons and the cycle continues. Any ideas?
  • 1 more comment
  • jmkr123 Apr 26, 2010
    Yes but I cant find the code for this particular beep cycle. That is what I'm hoping someone on here can tell me. Thanks for the assistance.
  • jmkr123 Apr 27, 2010
  • 64 Answers
The beep is a code to tell you what is wrong. POST - Power on Self Test. http://en.wikipedia.org/wiki/Power-on_self-test You can serach the web for more detail as well. Usually memory has popped loose or a connection is not seated fully.
Posted on Apr 26, 2010
  • Mark Zbylut
    Mark Zbylut Apr 27, 2010
    The POST beep error code is a series of long or short beeps. What is the pattern in the 18 second period before it repeats? Is it one long beep? Or is is something like long - long - long - short - short - long?
Installing new motherboard, processor, mem, and video adapter. Powers on but no post.
If the beep is a very high pitched tone, turn off the computer. Your CPU is overheating. The thermal paste may not be spread correctly on the CPU or the heat sink isn't properly installed.
Otherwise, it's probably a memory error. This machine takes 2 GB of memory as 2 single GB memory sticks. Try booting the machine with only one DIMM installed. Try each stick individually before getting replacement memory.
I hope this helps.
Jan 27, 2013 | HP Compaq Presario SR1215CL (82916052980)...
My dell precision 470 beeps loud for 10 seconds when i turn it on and it has no signal to any monitor any ideas?
Please refer to the beep error codes for your work station here: http://support.dell.com/support/edocs/systems/ws670/en/ug_en/advtrbl.htm#wp1058075
Usually a 10 second beep is an issue with RAM not detected/installed or an issue with CPU
May 27, 2012 | Dell Precision 470 PC Desktop
I recently turned on my hp 6500 f desktop computer and it gave like a 15 sec beep and stops for 10 sec and keeps doing itcontiniously don't know muchabout computers need help
The motherboard is detecting some "fault":
* RAM not properly "seated" in its socket
* video-card not properly "seated" in its socket
* "bad" RAM (that is not working correctly)
* overheating (fans inside the case no longer working)
Take your computer to a qualified technician, at any computer-store, for professional diagnosis & repair.
Nov 15, 2010 | Computers & Internet
No ring on lines on extension 11 and 12. How do I program to ring?
Please follow the steps given below
To set distinctive ringing
1. Press #9876 to enter User Programming Mode
2. Press a Line or extension button. The LED is steady green.
3. You can press Hold to switch between internal and external pitch.
(Internal = station calls within your system; external = outside line calls.)
4. Enter the two-digit pitch number (see table)
5. Press the same button that you pressed in Step 2 (Line or extension). Two beeps is a confirmation tone and “DATA PROGRAMMED” displays on your LCD.
Tone No.                   Frequency and Cadence
 01
     500 Hz 1 sec. On, 3 sec. Off, repeat
02           300 Hz 1 sec. On, 1 sec. Off, repeat
11          500/640 Hz 1 sec. On, 3 sec. Off, repeat
12          500/640 Hz 1 sec. On, 1 sec. Off, repeat
13           860/1180 Hz 1 sec. On, 3 sec. Off, repeat
 14         860/1180 Hz 1 sec. On, 1 sec. Off, repeat
15          1300/1780 Hz 1 sec. On, 3 sec. Off, repeat
 16         1300/1780 Hz 1 sec. On, 1 sec. Off, repeat
17          860/1180 Hz 0.5 sec. On, 1300/1780 Hz 3 sec. Off, repeat
18          860/1180 Hz 0.5 sec. On, 1300/1780 Hz 1 sec. Off, repeat
Thanx
Jul 22, 2010 | Toshiba DKT2010SD Phone
Screen stace dark, motherboard beep 20 sec long beep then
there may be problem with your RAM or processor
please check the on your friends pc
May 06, 2010 | Computers & Internet
My pc won't boot..I get very long beep, pause long
Try resetting the motherboard, by either removing the battery or changing jumpers on the motherboard. If this doesn't work, then motherboard is going bad.
Feb 19, 2010 | HP Pavilion a6600f Desktop PC
Computer beep problem
Try taking out all RAM modules and reseating them again, as it appears that one may not be slotted correctly. Be sure not to touch any of the Gold leads with your fingers, and of course make sure the power is off, the plug is removed, and then press the power button for 10 secs. to drain and charge in the board before proceeding.
Jan 10, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
Hp pavillion desktop will not power up. Blinking green light at power supply
Step 1 : Turn off the system by pressing the power button for 5 - 10 sec until the power LED is off. Removed all cables including the power cable (Exclude monitor cable and KeyBoard/Mouse).
Step 2 : Press power button for 5-10 sec again to drain fela power.
Step 3 : Reconnect the power cable at the back of the tower/computer and power on the system.
**If the same problem exists, Call HP tech Support (800-474-6836) because there is a high possibility that you have a bad Motherboard or Power Supply on the system.
Oct 28, 2008 | HP Computers & Internet
High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
Computers & Internet Logo
234 people viewed this question
David Payne
David Payne
