Question about The Times Case Corporation Tractors International Harvestor
No fuel to the injectors . changed fuel filter,bled fuel line , good flow. but nothing to the injectors. is there a fuse or relay that need to be replaced. and which one ?
    Problem Solver:
  • 6 Answers
What kind of tractor
Posted on May 18, 2010
  • baseball4dad May 12, 2011
    I have the same problem with fuel not flowing to the injectors on my 784 international.
1999 chrysler 3.5 lhs fuel not going to injectors
Then your fuel pump is not working, or your fuel filter is blocked. You will probably have to check your fuel pump circuit if you have no fuel pressure in the fuel rail, where the injectors sit. There is a fuse for the pump, usually in the under hood fuse/relay block. That is probably also where the fuel pump relay is located. You should hear or feel this relay click when the ignition key is cycled from off to on. Also, when the key is turned to on, you should hear the fuel pump in the gas tank turn on for about 2 seconds. This will put the pressure in the gas in the fuel rail, for starting the engine. If you don't hear the pump turn on for that 2 second period, it is probably a bad fuel pump. But know the fuse is good first.
Sep 25, 2015 | Chrysler Cars & Trucks
Changed fuel filter bled injector lines no fuel bubbling out fuel runs out of lines on injector side of fuel bowl will not pump fuel to injectors
Hi Lauren the easiest way to Blead these systems is to suck the fuel through the return line at the filter. This pulls all the fuel and air through the high pressure pump and primes the injectors. This is the most efficient way to do the job. Because even a small amount of air in the high pressure pump will prevent it from starting.
Apr 07, 2015 | Cars & Trucks
4cyl diesel Ford tractor. Ran great yesterday . Today it starts and cuts off. Any ideas?
Is the fuel flow strong at the injection pump ? If not you may have a partial blockage inside the tank, wouldn't hurt to change the fuel filters either. I had a similar problem with my 350 JD dozer
I checked the tank and found some debris covering the outlet hole,
debris removed problem fixed.
Also check all your fuel lines, if all the above is good, than start cracking each injector one at a time with the machine running
as long as it will run, you will notice a bad injector by the difference in sound , a good injector will cause rough idling l a bad one will not.
Aug 10, 2014 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Truck would not excellerate pas ten miles now it wont start. when i play with the fuel restart button it starts rough and dies
See there were several postings. Was internal fuel tank screen good when pump was changed? Was disposable fuel filter changed? I had similar problems and it turned out that the internal filter screen broke apart and clogged the fuel lines.
The crankshaft sensor was also bad as fuel pump was tested during internal tank filter work.
Also check your injector wires. Even having fuel pressure is nothing if the injectors are not opening to let fuel into the cylinders.
Dec 27, 2013 | 2007 Mercury Mountaineer
I have a 1999 chevy blazer that will turn over but won't start. prime with fuel runs untill it runs out. have code of p1351 in it
Need more info.......It could be the injectors are not pulsating...Check to see if it is spraying fuel from the injectors....If not it should be a clogged fuel filter or a fuel pump....It is almost definite though that it is the fuel pump/sending unit in the tank ...IF it is not spraying from injectors....
Disconnect battery remove main fuel line going in the fuel filter under vehicle frame at drivers side..with drain pan under it of course...Reconnect battery turn engine over and watch for fuel...
You will need an assistant...Most people think fuel is under great pressure but it is not.....If everything works the fuel will come out in a stream...But it wont come out like a bullet...
If fuel comes out Fuel pump in tank is good...Then your problem is at the injectors ...I would change the filter of course anyway...unless you just have...You will see rusty dirt come out of it if it is clogged...It is always good to change fuel filter every 15,ooo....Todays fuel is terrible...I would first check or swap fuel relay with a new relay or identical relay in fuse power block ...Make sure they are all good....................What engine and how many miles ? Hope this helps....Metalpoet
Apr 17, 2011 | Chevrolet Blazer Cars & Trucks
2002 GMC Sonoma 2.2l 4cyl. I have been having intermittent fuel pump problems. I replaced the fuel pump and now the truck will not start. There is spark and there is flow at the filter, but it is very...
With the ignition key turned on without trying to start the engine you should hear the fuel pump run for a few seconds. That is how its primed to start. Upon starting the oil pressure reaches normal operations & the prime switch will cut off by the signal from the computer. Thus the engine still needs fuel to run so the computer switches on the fuel pump relay to provide the fuel to the engine. The prime switch is intergrated with the oil pressure switch. If you do not hear the fuel pump upon having the key on replace the oil pressure sensor
Dec 28, 2010 | GMC Sonoma Cars & Trucks
Have a 1999 Audi A6 quattro, changed the fuel filter and bled the line. Car won't start. Has fuel all the way up to the rails. Is there a fuel pressure release/switch that is on the injector rails?
did you plug in the fuel pump at the fuel pump. did you cycle the key off and on at least 5 times check the plug at the fuel pump first to see if its still plugged in
Aug 12, 2009 | 1999 Audi A6
Air in fuel lines wont start air locked injectors, changed fuel lines front to back also changed fuel filter and t any ideas would appreciate
The injector system itself has air in it as well.It has to bleed out was what I was told when I ran my Scirroco out of fuel one time.
Jan 04, 2009 | 2000 Volkswagen Jetta TDI
Replaced fuel filter, now won't start
a cut off switch is almost never the problem just hummor me for a second and please check that the fuel filter is installed correctly not backwards then check the fuel pump fuse and relay if all good check for power at the pump and a good ground if all this is good then the pump need replacement
Oct 18, 2008 | 1998 Kia Sephia
The Times Case Corporation Tractors International Harvestor Logo
234 people viewed this question
Top The Times Toys Experts
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
