Question about Audiovox PVS33116 Player
Out unit will not turn on - I assume it is the battery but it seems odd it will not turn on when plugged in. Thoughts?
All 3 handsets seem to be dead at same time. It seems odd that they would all go out at same time. Is it simply a battery issue? The answering machine part works fine.
Check the line using an old conventional plug in phone. You should always keep one for power cuts. Also, get someone to phone your number.
One a three handset system, the signal to all three are driven by the main unit, the bit with the answering system. Check that is plugged in to the mains wall socket and if it is, check for power at the socket. If that checks out, you need to check that little plug in power supply unit. Best way is with a test meter. If the lights are on on the unit and the answer machine works, then you know you have power at that unit, so you need to check the power supplies in the slave units.
My guess is that your line is dead to the house.
Dec 23, 2015 | Lands Phones
My hotpoint keeps tripping out and won't stay on checked socket and plug both are fine
I assume you are talking about an electrical kitchen unit in a camper or trailer unit since you identify it as a Hotpoint (TM). Granted, it is my assumption, but I think it is valid.
From what you have said, I have to assume, also, that you are dealing with AC voltage not DC and it is standard 117 VAC.
Here are a couple of thoughts that I think are valid. First, look at the plug fiture itself. If it his a three-wire unit and has a reset button in the middle, I assume it is a ground-fault-isolater unit. GFI (ground fault isolator) units trip out, cutting the power flow. They are a safety feature (for further vehicle safety information, please visit Safecar infoCar safety Insurance Magazine ) in motorhomes, campers and trailers where it is possible for water to spill while you are using things like electrical kitchen equipment, posing a danger. GFI circuits cut out instantly a problem is found, ending the danger.
It is possible that the GFI plug, itself, is faulty and shorting out, causing the problem you note.
It is equally possible that the Hotpoint (TM) device itself is faulty and shorting out. It could easily cause circuit breakers to trip, cutting power, in this situation. This, it seems to me, is the problem you are describing. If you have any further information, please let me know here by placing a comment below.
Nov 22, 2014 | Cars & Trucks
Last night at a gig i was getting a high pitched feedback depending on where i was standing through my iems. also the red AND green lights were both on even with fresh batteries in (twice) Thoughts?
Feedback while setting up for gigs is a fairly common problem so I assume there was something different about it that time. Was it a mic or a guitar ? A real odd one for us (but which other bands have experienced) is that the venue had a hearing loop with mic(s)in the stage area and induced into the guitar pickups. If it was that it has to be turned off.
Oct 05, 2014 | Audio Players & Recorders
Altea 4 mobility scooter battery problem
hi, the battery's sound okay, have you made sure the scooter not in free wheel mode ? check the lever attached to the side of the brake ,,,
Check the wiring going to the axle .. At worse the controller has called it a day...at best a loose connection,,, controllers are repairable..
Regards
Rob
www.gewizrepairs.co.uk
Apr 20, 2014 | Pride Mobility Products Health & Beauty
I have purchased 2 Ibanez TS8DX Tube screamers. Both are broken right out of the box. I plugged a cable into the out jack and into my amp. I then pluggen my guitar cable into the IN jack. Pushed the pedal,...
The input cable MUST be a TS (unbalanced cable) to turn the unit on. The sleeve of the input cable is what connects the battery. If you use a TRS cable at the input it likely will not turn on. A TRS cable has a tip, ring AND sleeve like many 1/4 inch stereo cables.
Sep 15, 2011 | Ibanez Ts9dx Turbo Tube Screamer Overdrive...
What are the odds that the cruise control unit and the actuator unit would BOTH fail at the same time ?? 2002 Odyssey EX-L 172,000 with all maint from day one. Seems rather odd to me, but I'm NOT a...
Sounds like they are guessing and dont want to, or cant diagnose it properly. First make sure fuse is good (fuse 6) , make sure brake pedal switch is adjusted correctly. (if it thinks you are pushing the brakes, it wont cruise) check fuse 47 (if horn blows, fuse 47 is good) make sure cable is connected at throttle body. check these first, the rest gets complicated.
Aug 03, 2011 | 2003 Honda Odyssey
Suddenly, the handheld monitor turns off (no picture or sound) and will not turn back on, even when I plug in the AC adapter. The green light on the battery indicator is on, but the monitor won't turn on...
Mine jut did this. What did you end up doing. I did what other people said which was take the battery our and put it on the stand... NOPE... green light on but not sound or picture. I could hold the button down until the cows come home and it will not turn on.
Sep 23, 2010 | Summer Infant Slim Secure Handheld Video...
Hard to start 00' triumph 955i
I'll assume you did not mess with the fuel line, the bike is not in need of tuning and the battery is charged. Issue may be something else if the above is not true.
On my 2000 Speed Triple my headlight relay went bad. It left the headlights on when starting. The headlights are suppose to switch off so the startor could get more juice out of the battery when starting the bike.
Jul 15, 2009 | 2000 Triumph Daytona 955i
Garmin Ique 3600 - Won't charge at all
There are larger capacity baterys avalable.
I saw several different size baterys reported to fit the 3600 on the web.
I am currently looking for a parts doner 3600. If you want to part with yours.
Thx.
Alex
AlexRands@hotmail.com
Jan 01, 2008 | Garmin iQue 3600 GPS Receiver
No power
may need new backup battery but seems odd being new unit but you never know .
Dec 06, 2007 | Garmin StreetPilot C330 GPS Receiver
Audiovox PVS33116 Player Logo
19 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
