Question about Linksys Wireless-G WRT54G Router
We have comcast for cable connection. when the
The router is Lynsys wrt54g. we have comcast for cable connection. when the computer is pluged in the internet works but they wireless connection sais connected although the webpage sais that its not connected
  • inga2000 Apr 24, 2010
    just a home page. the connection status says that the connection is good but there is no way to go online to any webpage (google or gmail or what ever else)
  • MyPC Solutions
    MyPC Solutions May 11, 2010
    What webpage are you referring to?
    President:
  • 1,768 Answers
1. Reboot the computer that is connected "wireless.
2. Go to the DOS command prompt type "cmd" to get to this.
2. Next do a ipconfig /all this will tell if you have media connect. If not then do ipconfig /release >> then ipconfig /renew.
this is all done at the DOS prompt.
Posted on Apr 24, 2010
Cannot contect to apache through wrt54g
Highly unlikely. That would block all HTTP sites that use Apache. Even then, how would they distinguish one web server from another type. Your error is based on a specific site, or all internet if Comcast does not show their splash page saying it can't reach a specific site.
Dec 04, 2012 | Linksys Wireless-G WRT54G Router
I have comcast cable internet. How do I set up my wireless router to work with this
Connect your router to the Cable Modem using an ethernet cable. On the back of the router, plug the cable into the port labeled "Internet" which should be the port on the far right.
Go to the admin page "192.168.1.1" - change the Internet Connection Type to Automatic Configuration - DHCP.
Feb 07, 2011 | Linksys Wireless-G WRT54G Router
No more internet thru router after new modem installed
Router setup
Go to the control panel and un-install the program that the Comcast cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Did Comcast reset you wireless router settings? If so, you may need to set up your SSID and security settings.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 05, 2009 | Linksys Wireless-G WRT54G Router
Wrt54g router simply quit working on the base computer. This is not the wireless conection, but the cabled connection. Cable in from my modem and cable out from Port 1 to my pc. I was using the computer at...
The simplist solution is to try a full reset. There should be a recessed reset button on either the front or rear of the unit. While the power is on, press the reset button for about 10 seconds, and then release. The unit should re-set.
Then you will have to access the router via your browser to re-setup the parameters.
For details about re-setting the unit, and doing the setup refer to the user manual.
If the reset process does not work, there is a strong possiblity that the router is defective. It will be cheaper to buy a new router than sending it in for service if it is out of warranty.
Jerry G.
May 15, 2009 | Linksys Wireless-G WRT54G Router
Why does this keep happening??? Please advise...
Your modem is set to only allow one main IP address, which it assigned to your laptop.
Connect the cables through the router, then unplug first the modem, then the router.
Wait 45 seconds, then plug in router, wait 5 seconds, then plug in modem.
Give it a few seconds to talk to everything, and you should be good to go.
Dec 04, 2008 | Linksys Wireless-G WRT54G Router
I can't connect my WT5462 V1 wirelesswly to my computer.
you first have to have a hard wire connection on your computer,go to www.lynsys.com and download firmware and install wizard it will walk you thru the rest,I just installed mine and you wont be dissapointed it really is a great router
Sep 26, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
I just got my first notebook it is a compaq evo n400c with a belkin 802.11b (32 bit cardbus)wi-fi card. i am trying to find out how i can get/have internet access where ever i go. how do i go about setting...
Hi Obadiah,
U can take ur laptop to any of the hotspots and u need to turn on the wireless switch in ur laptop so that u can automatically connect to the wireless internet..i think u r aware about hotspots...
If u want to use internet in ur home..u can buy a wireless router..there are lot of companies providing wireless routers..u can buy Linksys..model no is Wrt54g..this wrt54g is a wireless router where u can connect 4 wired desktops and 20 wireless laptops..its cheaper and best.u need to buy a internet connection to connect this router...I suggest u to go for a cable Internet..Cable internet providers are comcast,shah.go for comcast.Hope this info will be useful for u.for further clarifications revert back as soon as possible
Jul 09, 2008 | Belkin Computers & Internet
Linksys Wireless-G WRT54G Router Logo
66 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
