Question about Ovens
Our brand new kitchen aid oven will blow hot air for up to a half hour after it has been turned off. This seems unusually long- what is the expected time of cooling off?
  • Ovens Master
  • 43,501 Answers
That depends on the ambient temperature in the room..if your room is fairly warm you can expect it to take longer then if the room is cool...
I would say though that 1/2 hour is pretty normal...it is good to get the unit cooled down, the less time it is warm the longer it will last... heat kills ovens...even though they are made to take heat...
heatman101
Posted on Apr 24, 2010
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
Needd to change kitchen aid wall oven from celsius to fahrenheit
Press and hold the Broil Max Econo button for 5 seconds.
Only this button and without turning on oven.
Feb 17, 2013 | KitchenAid Kitchen Aid KEBS177SBL Single...
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    We lost power to the entire home in the middle of the self cleaning cycle of the KitchenAid oven. Now the keypad control panel has gone blank and we can't get it to turn back on. Tried flipping the...
    there is a thermal fuse in the back or on top of the oven that is blown. its designed to blow if the oven gets too hot. you will have to remove the oven from the wall to check it. thats probably why kitchen aid wants to send someone out.
    Feb 03, 2011 | KitchenAid KEBC208 Electric Double Oven
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    I cleaned over with self clean and it blows the thermostate. Is this normal on Kitchen aid wall mount ovens?
    if u have unproper vent specs on unit it will blow. read instellation spect for proper vent specs
    Feb 12, 2010 | KitchenAid Architect Series KEBC177KSS...
    I have a Kitchen Aid oven, model #KEBS107DWH2 and the hinges are "sprung" so the door will not close all the way to turn off the oven door sensor, unless you prop something up against the door. That said,...
    You are very lucky if that machine lasted as long as it has. if you replaced those hinges in 2007 that's 10 years. The last one i bought they said we will be lucky if we get five to ten years out of the new one. Unless you want to put money in this one its probably cheaper to buy a new one in the long run.
    They could not care less if you tell them you won't buy anything from them again. I had a large company official tell me that.
    Apr 08, 2017 | KitchenAid Ovens
    Kitchen Aid Double Convection Oven blows circuit breaker
    the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
    Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
    Kitchen aid, self cleaning
    The only solution is to get a new oven, The paint in the oven burned off, and now the electic board is burning out. This oven when it hits about 400 degrees it makes this chemical plastic smell, and at selfcleaning it makes the same smell for 3 1/2 hours, and come to find out it burned the paint off
    Jan 04, 2009 | KitchenAid Architect Series KEBC107KSS...
    Ovens Logo
    57 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
