Question about Meade 494 AutoStar Telescope Control Unit (Handbox only)
Stalling out why does my 1989 ford f 150 keep stalling out while driving, sometimes it will start back up sometimes it won't?
  • 3,186 Answers
You posted this in the Telescope forum by mistake.
Posted on Jul 30, 2011
SOURCE:
I need a service manual with wiring diagrams for a 1989 ford f150 1/2 ton 2 wheel drive 5.0L
http://cgi.ebay.com/ebaymotors/1989-89-Ford-F150-Truck-Repair-Manual-NEW-_W0QQcmdZViewItemQQhashZitem3a5e4465edQQitemZ250689644013QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Copy and paste that in your browser. Or go to ebay and type in 1989 ford f-150 repair manual. Or go to Autozone and sometimes they have it.
Sep 04, 2010 | 1989 Ford F 150
89 F-150 5.0 EFI I got spark, Got fuel, Turns over but Wont start...Any ideas?
if truck does not start it sounds like a bad crank sensor! have it scanned to be sure. a bad crank sensor as it controls timing more than likely engine will not start at all. engine back fire or irregular rpm function. no start and no pulse to injectors, car will stall when stopped. p0335 to p0342 are the sensor problem codes.
Aug 21, 2010 | 1989 Ford F 150
1989 Ford aerostar van sputters and stalls.
have you had the throttle cleaned? Sounds like your fuel pump may be getting hot and cutting out. Its possible it could be a faulty ignition module,but that usually just causes a no start not a suptter and stall.
Mar 04, 2010 | 1989 Ford Aerostar Cargo
Engine stall when put in gear
Try changing the fuel filter, and if that doesn't help, get back to me.
May 22, 2009 | 1989 Ford F 150
1989 Ford F150 idles rough after start and stalls out some
i have a 1991 f-150 and had the same problem try changing the fuel filter and put gas treatment in the tank alone with fuel injector cleaner if that doesnt work you mite check the fuel pump and see if any rust or dirt is in the tank cloging things up
Apr 15, 2009 | 1989 Ford F 150
2002ford truck explorer when i frist start my truck it will stall out a few times then wiil run good for awhile then for some reason stall out 3 or 4 times some times i can drive for 150 miles with no...
it sounds to me that you idle controll valve isnt responding (could be dirty) get a can of carb cleaner and clean the thottle body inside and with the engine running. squirt just a little and the engine will start to stall and the idle air controll will start to open ( you will hear it start sucking) then spray more in sperts try to keep the engine running at idle . this will make the engine RPM's change and open and close the idle controll valve thus cleaning it. when done save some carb spray. put the air cleaner hose back on. and start the engine and with the engine idling spray around the intake and base of throttle body if the rpms change you have a vaccume leak than will need to be repaired.
good luck
tech rating 3
Aug 23, 2008 | Ford Explorer Cars & Trucks
1989 Ford Festiva, keeps stalling as driving.
I had the exact same problem. The cooling fan was failing to come on and thus overheating the engine. Check the cooling fan, cooling fan thermoswitch, and cooling fan relay ( behind drivers headlight ). If you pull the connector off of the thermoswitch the fan will come on whenever the car is in "run"
Aug 18, 2008 | 1989 Ford Festiva
Optics Logo
62 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Gep Pep
Ekse
Are you a Meade Optic Expert? Answer questions, earn points and help others
