Question about GE Energy Star WCVH6260F Front Load Washer
GE washer not starting
I have a front-load ge washer model: wcvh6260hww. I ran a load and it worked fine. The next load I put in, pushed Start, and there were three buzzing sounds, after about 2 minutes, the washer sounded like it was trying to fill with water, but no water was coming in and the washer never started. The water is working, I think it may be the control panel, any thoughts?
Thanks.
    Sergeant:
  • GE Expert
  • 211 Answers
Fill screen are clog with dirt
Posted on Apr 25, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
Front load GE wcvh6260hww gasket is ripped Where do i get a new one and how do i replace?
I have not replaced a gasket myself (had warranty service) but when it was complete, I made sure to tilt the washer slightly backwards so the clothes did not get into the gasket so easily. After two replacements in the first three months, we have not had to replace for more than two years. Hope this helps when you get the new one in.
Oct 16, 2010 | GE WSXH208A Front Load Washer
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
I bought a GE front load washer last year model # WCVH6260HWW now I'm having problems with it. It keeps shutting off during a load. I push the Start/Pause button to get it going again, sometimes 3 or 4...
I have the same problem, and I believe it is because the filter is full. I'm tracking down the repair process now.
PUMP FILTER CABINET, COVER & TOP PANEL 285 WH23X10029 $68.00
I've downloaded the exploded view from GE.
Jul 01, 2009 | GE Washing Machines
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
Front load GE washer
you just push the delay button once and the light will go off.
Oct 17, 2008 | GE WSXH208A Front Load Washer
GE FRONT LOADER WASHER Model#: WBVH5100HWW
You need to put the setting on whites in order for it to take the bleach. Not sure about the fabric softener. I use dryer sheets
Jan 19, 2008 | GE Model: WCVH6260HWW Kitchen Hood
GE Energy Star WCVH6260F Front Load Washer Logo
686 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
