Question about Philips HTS-3555 System
Home Theater System
There is no power to the receiver
  • 4 more comments
  • Anonymous Jul 06, 2008
    Our system has also entirely lost power.
  • Anonymous Aug 23, 2008
    no power,dead set
  • keeperdesign Aug 23, 2008
    The unit's power button stopped working months ago (6 months after purchase) but the remote powered it up without incident. However, as of this morning, the unit won't power up at all. The red "stand-by" light remains on (even when unplugged!), but unit wn't power up.
  • czernik7 Sep 21, 2008
    second phillips home theater system in one year! will not power up! do not waste your money on these units hts3555 junk. no help from phillips support
  • Anonymous Sep 28, 2008
    blinking light
  • Anonymous Oct 29, 2008
    Lost all power after about 3 months of occasional use.
I have the same problem as of last evening just shut off and will not power up.
Posted on May 01, 2008
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 26, 2011 | Panasonic Home Theater System System
Not powering on .the volume light is blinking
Try Disconnecting all the speakers then powering up. It sounds like it has a short :/
Jan 05, 2011 | Coby DVD-937 5.1 Channel DVD...
Page 42:
No sound. The system cord and/or speaker cord is not connected. Check the connection.
The audio cord is not connected to AUDIO IN (VCR)
and/or DIGITAL IN (DBS) correctly.
Connect the cord correctly. (A pg. 13)
An incorrect source has been selected. Select the correct source. (Apg. 17)
The decode mode is not set correctly. Select the proper decode mode. (A pg. 35)
Do you think the powered subwoofer itself might have a power problem? Check its cord.
Dec 26, 2010 | JVC THC5 Home Theater System with 5-Disc...
My parents are getting rid of their Panasonic SC-HT700. The receiver is shot. The speakers and sub work perfectly fine. I was wondering if I could purchase a used receiver (found the SC-HT930 on ebay) to...
the speakers are 6 ohms, and it will be very difficult to find a receiver that is 6 ohm compatible. most home amps are 8 ohm, and will overheat and burn up when used with 6 ohm speakers.
the subowoofer is 4 ohms, but i am unsure as to whether it is self-powered, or if it is powered by the receiver.
4 ohms is the standard for car audio, and 8 ohms for home audio.
Oct 27, 2010 | Panasonic sa-ht930 Home Theater Audio...
Hooked up home theater system, sound but no picture
are the red and white for "audio in" to the theater system receiver and the yellow cable hooked up to "video out" on the receiver and "video in" on the tv?
Typically most theater systems do not have "audio out" connections because they produce the audio. The receiver will have several "video out" connections, one of which needs to go to the tv.
Mar 12, 2010 | Audio Players & Recorders
RCA RT2870 home theater system 'welcome' screen
Well, I just returned the unit. RCA replied with the following solution:
Let the unit sit with the AC power cord out of the wall for a couple of
hours. Then hit the power button 10-15 times (with the AC power cord still
out of the wall socket!) and then try again.
Oct 02, 2009 | RCA RT2870 Theater System
No Audio with home theater system
have you tried infra red link?
May 07, 2009 | RCA RT2760 System
No home theater sound
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Mar 07, 2009 | Denon AVR-4800 Receiver
Philips HTS-3555 System Logo
230 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
