Question about Apple iPod touch
My ipod is locked will not allow me to connect to itunes
Only itunes appear on the screen.and i cannot open my ipod.what is the problem
Posted on May 11, 2010
My ipod is disabled and says connect to itunes but it also says itunes could not... so what do i do?
Step 1:
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly unlock your iPod Touch.
Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore." When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore." After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration. iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Mar 01, 2013 | Apple iPod touch Original
Got locked out i pod touch
How to Unlock a 16GB iPod Touch
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
Dec 05, 2011 | Apple iPod nano
On my ipod touch, it says that ipod is diasabled and connect to itunes. when i connect my ipod touch to itunes, itunes say that itunes cannot connect to ipod touch because it is locked with a passcode. i...
this is the solution for this kind of issue. please try it. It might work on your ipod touch.
please click here
hope this helps . . . please don't forget to vote for this solution if this works for you :) . . . thanks
Apr 12, 2010 | Apple iPod touch
My Ipod touch is disabled Please HELP ME
If it was locked and you donot know the password then the only thing you can do is restore it using dfu mode hold both power and home button until it turns off and restart and show you to connect to iTunes2_bing.gif. Then restore it. Let me know what happened.
Dec 19, 2009 | Apple iPod touch
My ipod touch says its disabled and to connect to itunes, but when i connect to itunes a password is needed. But my touch will not allow me to enter a passcode.
Dec 13, 2009 | Apple iPod touch
Locked i pod
Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod.
For example, if you use Screen Lock and then connect your iPod to a computer, you'll still be able
to manage music on your iPod with iTunes and access all data on it in disk mode (contacts,
notes, and any other files you have stored on the iPod).
To unlock it, connect iPod to the primary computer you use it with (the first one iPod synced with),
and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using this method, you can restore your iPod to factory settings. Please
note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
To restore your I-pod, do this:
1) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software
may need to be downloaded to your computer.
2) Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that
came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes.
3) Select your iPod in the Source panel and you will see information about your iPod appear in the
Summary tab of the main iTunes windows.
4) Click the Restore button. You will be prompted with one or more restore options that may prompt
iTunes to automatically download the latest iPod Software. Use restore option 4.
Sep 17, 2009 | Apple iPod nano
Refurbished iPod locked
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Aug 12, 2009 | Apple iPod touch
Double Problems...
this problem happens when you try connecting a ipod to a new Itunes. If you know the lock code you can remove it temporarily until you have it connected and authorized for that computer then you can apply a lock code to it again. the lock code can be removed by going to the settings icon then general option and turning off the passcode lock. then plug into your computer and Itunes will start and go and authorize that computer then all should be good.
Aug 05, 2009 | Apple iPod touch
Locked forever
In the Apple Support Site, Apple notes that the "Screen Lock" function:
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This supportdocument aso provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize.
May 26, 2009 | Apple iPod touch
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
