Question about Karcher 2500 PSI Pressure Washer
I have a G2600 Karcher pressure washer. What is
I have a Model # G2600 VH Karcher pressure washer. What is the spark plug gap setting?
5 Suggested Answers
comax
  • 154 Answers
SOURCE: Does anyone know what the spark plug gap setting
Most gas engines will work fine at .030 to .035 sparkplug gap
Posted on Apr 16, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
  • 420 Answers
SOURCE: Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Posted on Jul 20, 2010
MOTORWIZJ
  • 1358 Answers
SOURCE: I have a husky 2200
20 thousands or about the width of two match book covers stacked.. there not that fussy, good to be close though
Posted on Jun 06, 2011
Power washer won't start
Does it have spark? Is it getting fuel to the cylinders?
Oct 13, 2016 | Karcher Garden
How do I fix a Karcher 2600 PSI pressure washer has water in oil..
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Aug 09, 2014 | Karcher G 2600 VH Gas Pressure Washer
I have a Karcher G2600 OR, It sprays with full pressure for 1 secound and then it stops for about half a secound. it keeps repeating this constantly. I have checked the seals and the pressure valve and...
sounds like a bypass valveproblem try backing off your control valve and see if it clears up. also make sure your hose and nozzle are free from debree.
Jul 05, 2011 | Karcher Garden
QUE TIPO DE ACEITE USA LA KARCHER GC160
tengo una maquina honda gc160 5.5
modelo g2600 vh con seria 152 428
Jun 29, 2011 | Karcher 2500 PSI Pressure Washer
IT HAS PRESSURE BUT IT PULSATES INSTEAD OF STEADY SPRAY
I have same model with same problem. Tried the easy fixes:
unloader valve lube and clean, inlet water sufficient, and nozzles and hose are fine. Broke down pump and called for parts (about $50 for 3 inlet valves and some seals) hopefully this will fix it. Mine has been used in my business pretty hard for a few years, so not bad.
Joebro
Jun 11, 2011 | Karcher G 2600 VH Gas Pressure Washer
Accidently put 2 cycle gas into Karcher G2600VH, Drained gas,Took spark plug out and cleaned. It is running fine now is there anything I should do in addition
Placing 2 cycle gas into a 4 cycle engine does not cause problems (but will blow white smoke and, in time, dirty the plug). I would have probably just ran it through.
:o).
Jun 04, 2011 | Karcher G 2600 VH Gas Pressure Washer
Can the pump be replaced? If so can it be a "do it
yes, the pump can be replaced but I would recommend trying to repair the pump first, see this link to repair the unloader valve, 9 times out of 10 this is the only issue with the pump
Nov 05, 2010 | Karcher G 2600 VH Gas Pressure Washer
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
What viscosity oil is recomended for oil change?
  • Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
May 24, 2010 | Karcher G 2600 VH Gas Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
90 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
