Question about Akai Televison & Video
AKAI PDP4273M1; picture just went out - Akai Televison & Video
  • grnlvl Apr 24, 2010
    I was told that there is no inverter board on a plasma tv. Can I repair or replace this power supply myself?
    President:
  • 1,768 Answers
You have a power supply issue and or a luminous tube (florescent ).
There also may be a inverter issue which points to a repair at the board level. A tech will be able to determine this with test where the issue is on the main board.
I hope this helps.
Posted on Apr 24, 2010
What type of cords do I need to hook up a akia PDP4273m1 to my cable box
Which cable box are you trying to connect to the PDP4273m1? The best choice of cable will depend on the outputs available on the cable box. If your cable box has HDMI (looks like a rectangle with small cutouts on one long side) out, get an HDMI (type A on both sides) video cable and connect it between that port and the TV's HDMI in. (This connection doesn't require an extra audio cable.) If your cable box has a DVI (out, get a DVI to HDMI adapter and the HDMI cable (or a DVI to HDMI cable). Connect the DVI side to the cable box and then the HDMI cable to the TV Then get an RCA audio cable (two male ends on each side, usually red and white). Connect this to the audio out jacks on the cable box and to the DVI audio in ports on the TV.
If you do not have either of those outputs, check for a component video/audio output. Get the component video cable (with 3 RCA plugs on each end - red, blue and green) and an RCA audio cable. Match the colors on each side as you connect the devices.
If those aren't available, the S-video or composite video cables will work. The composite video cable comes with the audio connectors (red, white, yellow RCA plugs). They aren't part of the S-video cable and must be obtained separately. These are limited to standard video (no HD) so they are not the best choices with your tv.
If your cable box has SCART out, you will need an adapter for that. Most provide composite or S-video out. See http://www.svideo.com/scart2.html for one of these. Note: you will need to match the adapter to the CART output or get a converter.
The connections should be from the left side: serial port (RS-232 for service), HDMI, digital audio out (for connecting to a home theater receiver), DVI audio In, two component video and audio in, a composite video/audio in and out and an S-video with audio in. The manual for the PDP4273M1 is available from Retrevo here: http://www.retrevo.com/support/Akai-PDP4273M1-TVs-manual/id/741bh140/t/2/ . You will need to enter a code to download the manual.
i hope this helps. Please add a comment with your cable box make/model/provider if you want more help.
(very few TVs come with the A/V cables these days. Some set-top boxes will come with the composite video cables.)
Jul 15, 2012 | Televison & Video
We ahve an Akai Projection TV PN# PT4298HDX/SMS TV turns on but no picture
Sounds like your bulb went out, I would call the manufacture or a local TV repair shop to find the part.
Akai Corporate: 323-281-0782
Aug 27, 2011 | Akai Televison & Video
I have A three year old AKAI 42 inch plasma tv---PDP4273M1---Mostly used as PC monitor. It was working just fine when I turned it off. When turned back on the next day, the on indicator light came on and...
Check to see what input setting the tv is on. It could still be looking for a signal from the pc input connection and no pc is hooked up thus getting no signal. Have the device you are trying to display on the tv connected and turned on and cycle through the inputs on the tv until you get a signal.
Sep 07, 2010 | Akai PDP-4216M 42 in. Plasma Television
No picture anymore
I found one of these at the dump with the same issue. Bought a Z sustain board for $75 , replaced it and it works great. I plan on installing some PC style cooling fans in the cabinet as heat is what destroys these sets
Sep 08, 2009 | Akai PDP4273M Television
Picture on Akai PDP4273M1 suddenly degraded drastically - no whites, very low contrast. Turned it off for 10 minutes then back on, instead of bright blue I get most black splotches with some blue. Any...
You could smash the TV and find that it will work better or call a local repairman. I know the exact problem with this TV, but only a technician should even open a TV. The guy I got the TV from totally butchered the inside of his Akai in a failed attempt to fix his TV himself. Instead, he created a fire hazard and is lucky he did not burn his house down.
Apr 30, 2009 | Akai PDP-4247 Television
AKAI PDP4273M1 - Unit powers up then shuts down.
I just repaired one for the same trouble. The input to the main processor from the standy switch had shorted to groung. This was probably caused by static inserted when pushing the power button. The processor is not a replaceable part. The part number for the main board is E3761-058010-2. It costs between $140 and $150. I found it on-line at Shopjimmy.com.
Good Luck!
Jan 29, 2009 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Akai TV repeatedly turns off and on
Yeah. I had the same problem. About 1 month ago my AKAI PDP4273M1 TV began turning off...then on. I happened to stumble on a temporary solution. I held one of the buttons down on the t.v. without letting go...and what do you know....the tv stayed on. So I rigged it to where the button (the "source" button) stayed in and I stuck a small object into the hole next to it (a small nail in my case). The catch is you have to use the remote becase none of the buttons on the tv work. Wonderful...so...I got that fixed and then today my picture gave out about 75 percent. What a Piece of S%#* TV. That is all I can say. My 2 1/2 year old TV is a POS and is going into the dump. Can you say hello to a new VIZIO. Hope that helps. Remember. NEVER BUY AKAI TV PRODUCTS AGAIN!!!!!
Jan 19, 2009 | Akai PDP4273M Television
Akai PT5598HDX/SMS won't turn on
Its busted. Try resetting it as a last resort, unplug the AC, wait 1 minute, then plug back in. If that doesn't work, its in need of professional service.
Jul 29, 2008 | Akai LCT2715 27 in. LCD Television
Akai pdp4273m1 has sound but no picture
I also have the akai PDP4273M1 tv with power and no picture and I looked at the power supply board inside and found 1 of the FMG26S chips blown and I am looking into replacing this to see if that does it and if not do a search for SANKEN PSC10165B M and for approx 170.00 you can get a whole new power supply for it and its easy to put in..
Jul 14, 2008 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Picture went out on Akai
I have the solution.  Call me  910-8936663
Oct 15, 2007 | Akai PT5492S 54" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
