Question about Kenmore Quick Clean 30012 Vacuum
My kenmore quick clean vacuum cleaner has no suction. Just seems to blow the dirt out and away from the cleaner. The canister is empty and the filter is clean, so what's going on?
  • Kenmore Master
  • 43,501 Answers
The hose or hoses are plugged...take all the hoses apart and stretch them out... run a stiff wire through them or something like a broom handle...you will find that they are full of dust and dirt inside...
heatman101
Posted on Apr 25, 2010
We have a dirt devil that when the canister is engaged, it no longer has suction. The canister is empty. Thoughts?
you turned the switch to blow instead of suction
remember them days .. no .. i do
Jan 12, 2015 | Hoover Vacuums
What causes poor suction on model ud40270? It seems like a lot of air is blowing out the front where the filter is.
Susan:
First, remove and clean or replace all of the filters in the machine. There is an inlet filter above the dirt collection cup. and an exhaust filter at the front lower part of the top of the vacuum head. If either filter is clogged, you'll get poor suction. Also lay the machine on it's back, and check the tunnel where the dirt goes up into the machine (behind the beater bar) to see that it is not clogged.
Jan 08, 2015 | Filter Vacuums
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
My Dyson DC40 Animal sounds like it's running on half power. I've only had it one day and it seemed great considering it was sucking up an incredible amount of half/dirt. I took the canister to empty it,...
I would recommend you check the gaskets and make sure they are all connected properly so the vacuum doesn't lose suction. Also, check the filters. If they get too dirty the vacuum will lose suction.
You could check out Dyson's site: dyson.com/support.aspx
Hope that helps.
Greeley Epoxy Garage Floors
Aug 24, 2013 | Dyson DC40 Animal Upright Vacuum -...
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
I have a dyson dc 17 what is the best way to thourghly cleaning , so I can get better suction , also do you have a instruction manul to. I seem to have misplaced mine thanks
The first step towards improving the suction is to clean the circular HEPA filter. The filter also houses a circular sponge which should be rinsed and dried before putting it back. Check the HEPA filter to see if it needs replacement -- will look muddy! Another quick check is to remove the HEPA filter, run the vacuum cleaner momentarily in upright position to check if suction is restored at the hose end.
After doing this if suction is still poor or non existent, you should detach the transparent canister - a bit tricky since the release rod for the flap has to be aligned when you want to reassemble the unit.
Once the canister is removed, you should check and clean the center tube/shaft for any clogged dust (use a wire coat hanger if needed to pry out the dust). This tube gets clogged if the vacuum cleaner was used to pick up damp/wet spills etc.
Sep 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Lost suction
TOSS IT and forget it! I have never used a hand vac that worked that was worth the effort of turning it on .... I suggest they are all junk ... I found very few vacuum cleaners ... actually **** especially anything made by dirt devil ... I do have a bagless Bissell 6579-2 that I purchased 4 years ago at walmart for $49 ... It outperforms any vacuum I've ever used, including my worthless Shop-Vac that I paid a lot more for ... this Bissell vac SUCKS ... It could **** the barnacles from a steamship!
Apr 28, 2009 | Dirt Devil Vibe AllPurpose Hand Vacuum...
Hair gets stuck in upper filter basket instead of going into the lower basket that you are supposed to empty. It is a Bissell 37604 Lift-Off Revolution Pet Bagless Upright Vacuum Cleaner
Check both filters. If one or other is increasingly dirty, wash or clean it out. Also check the air waves leading to the bagless bin canister part. If one air way is blocked the remaining dirt will try and access the bin other way due to the natural vacuum suction aspect.
Apr 19, 2008 | Vacuums
Vacuums Logo
549 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
