Question about Gigabyte RADEON HD 4650, Video Card
I installed a radeon hd4650 and now I have no sound. It says in device driver that there's no audio device. I do not even show a volume control. Help!
  • danettewumke Apr 25, 2010
    Thats pretty much what I assumed, I am hoping maybe someone might know exactly what I need to download and where I might find it, to fix the issue. Ive been banging my head against the wall for 3 days now trying to find anything to fix it.
  • 4 Answers
Sounds like the video overtook the sound driver i would try and remove and replace your sound card or if it is onboard sound remove and replace the driver. Also try and find an update for the video cardthere might be an update on that issue.Best of luck.
Tom
Posted on Apr 25, 2010
Do not apear the speakers icon
jmcabcd,
To Display The Volume IconBy default, the Volume icon is not displayed when you initially install Windows XP on your system.
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
If needed you may need to reinstall the sound drivers back into the system.You can download the drivers for your system by clicking the link below.
Latitude D400 Sound Drivers
http://www.dell.com/support/drivers/us/en/19/Product/latitude-d400
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 12, 2013 | Dell Latitude D400 Notebook
I need the audio & vedio driver ddr101
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 01, 2011 | Intel D101GGC Motherboard
No sound
Hi
Have you muted it by accident ??? try pressing FN+up and down volume key normally have a sound picture on it like a loud speaker
or go to control panel
sounds/audio
to make sure that it has not been muted in there
if all else fails try here for another audio driver
download it
install it
restart
and all could be good
good luck
www.realtek.com go up to downloads and choose HD audio driver
Feb 25, 2011 | Panasonic Toughbook CF-51 Notebook
No audio even i already installed the audio driver
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Feb 02, 2011 | Asrock P4VT8+ P4 PT800 Prescott Ready...
Volume speaker icon not show
The volume speaker Icon wont show usually because you have no sound drivers installed. To confirm this,
1) Go to your control panel and double click on "Sounds and Audio devices"
2) The window that appears sholu show the device volume slider active - which means the driver works fine and is installed. If this is so, click on "place volume icon in task bar".
If not, you need to install the sound drivers for your device.
(Don't forget to rate my solution)
Dec 02, 2010 | Audio Players & Recorders
Internal speakers do not work
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 30, 2010 | Acer Aspire Predator AG5900-U3092 Intel...
I am not a computer person but we did install a new Radeon hd 4650 video card in my son's hp. The Best Buy Geeks looked it up for our model and said it was compatible. We put in a new power supply. The...
Are your speakers plugged into the 3.5 mm jack on the system?
When you install the Radeon driver, it can sometimes change the default audio output to the HDMI port on the video card. For various Windows OS versions, you need to set this in the audio section of the Control Panel. The specifics may vary. For versions before Windows 10, Click on Start and select the Control Panel. Then choose the Hardware section. Find the Sound section and Manage Audio Devices. In the Playback tab, right click on the correct audio device (Speakers) and select Set as Default Device. Depending on the system, you'll probably see AMD HDMI Output and Digital Output. For Windows 10 before the Creator Update, right click on Start and look for the Control Panel. After the Creator Update, you'll need to click on Start and expand the Windows System folder.
I hope this helps.
May 06, 2017 | Gigabyte RADEON HD 4650, Video Card
Gigabyte Radeon HD 4650 1GB (AGP) - unknown PCI device
Hello.
ATI (AMD) does not "technically" support AGP products, but go to this link.
http://support.amd.com/us/kbarticles/Pages/CatalystAGPHotfix.aspx
To download the driver. Versions 9.6 and 9.7 will work, depending on your OS. Just download and install the drivers and the yellow exclamation mark will go away.
For more information please visit: http://forums.amd.com/game/messageview.cfm?catid=260&threadid=117644
Hope that Helps.
Jan 29, 2010 | Gigabyte RADEON HD 4650, Video Card
Radeon HD 4650 = NO audio
uninstall the ati sound utility, these video cards have a built in high def audio chip for sound thru hdmi
Dec 07, 2008 | ATI Diamond Multimedia Stealth RADEON HD...
No sound device found
check for devices in "other devices" in Device manager
Oct 22, 2007 | Computers & Internet
Gigabyte RADEON HD 4650,  Video Card Logo
246 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
