Question about Dryers
My Maytag dryer is warm inside and to touch, but not run for 2 days
    Habit-Forming:
  • 143 Answers
Unplug your dry your element on dry might short to ground cauing the element to stay on! call a techincian! but UNPLUG DRYER CAN CAUSE A FIRE
Posted on Apr 25, 2010
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
My daughters Maytag Atlantis electric dryer model# MDE7400AY has just warm heat, taking an hour to damp dry towels, and there is NO lint in trap. Checked to make sure exhaust pipe is not clogged, and found...
cleaning the vent is always a good thing, But check the outside vent cover, some of them have a flap inside that sometimes get clogged with lint especially if damp, The only way for moisture to leave a dryer is to have a clear shot for the heat to escape , thats all done through the vent, if it has moisture in it, something is blocking its escape
Jul 13, 2011 | Maytag Dryers
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Feb 27, 2009 | Maytag PYE2300AY Electric Dryer
Dryer Run too long
MAKE SURE YOUR LINT TRAPS AND DUCTS ARE NOT PLUGED.EASY REPAIR.YOU CAN DO IT.
Jan 16, 2009 | Maytag PYE2300AY Electric Dryer
Dryer Run too long
check the complete ventillation duct( in and out of the machine.) Sounds like its not moving any air. No flow
Jan 16, 2009 | Maytag PYE4558A Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
