Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
My dryer doesn't give out any heat when drying
  • Hotpoint Master
  • 43,501 Answers
If you have a gas dryermy dryer doesn't give out any heat when drying - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 25, 2010
Barrel isn't turning.
I believe you will find the belt is broken.
There is a motor which is supposed to turn a belt, which in turn drives the drum.
If you wish to repair ir yourself, a letter to "Fixya" could cause someone to walk you through the steps.
Be blessed.
Mar 04, 2013 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
My dryer doesn't want to dry clothes
is it getting hot if not maybe your heating element .There is also little sensors thru the dryer one may be bad
May 21, 2012 | Kenmore Dryers
Dryer heats and tumbles but doesn't remove lint or dry clothes in one cycle
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 09, 2011 | Dryers
Runs fine Doesn't dry clothes, not enough heat?
You will first need to determine where the problem is, I would disconnect the dryer vent from the dryer. Now if the drying improves, problem is not the dryer, its the vent system. If no change, does the unit heat at first then slowly fail to heat? Does it produce any heat? I need more information to direct you in the correct direction.
Please get back to me
Sep 08, 2011 | KitchenAid KEYS700LQ Electric Dryer
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
My stackable washer/dryer is taking at least 3 cycles on high heat before it will dry one load. It's heating up but it doesn't get hot enough. I've checked the venting and it is clear and...
heatman101
Jun 19, 2011 | Electrolux Dryers
Our LG DLE5977w dryer doesn't dry our clothes. The drum turns and there is heat, but it seems there is no air flow. We checked the vent hose and no clogs. When we cut it on the "drying"...
heatman101
Jun 18, 2011 | Dryers
Dryer takes too long to dry clothers and yes I cleaned all the vents and there is no clog or stoppage in vents
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 06, 2009 | Estate TEDS740JQ Electric Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
44 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
