Question about Amana ARGS7650SS Gas Kitchen Range
Oven temp Recipe calls for oven temp 1/2 hr at 400 then lower to 350. How do Iower temp while cooking?
    President:
  • Amana Master
  • 2,651 Answers
After youve cooked at desired temp(400) for allotted time. turn off oven, and restart at 350. it wont start up right away( its already at 400, but it wool drop in temp and cook at 350. good cookin to ya!!!
Posted on Mar 23, 2008
Baking in the convection oven, do you set the temperature 25 degrees lower than the recipe calls for?
temperature settings in ovens vary make to make
set around the receipe recommended temp but remember that most on tv cooks always say around the temp ( around 180 or around 250 for about 1hour or about 10 minutes
When cooking , nothing is set in concrete so to speak
Jun 04, 2017 | Ovens
Right setting for cooking cakes
depends on the type of cake .check the recipe and proceed from there some are 350 others go up to 400 degreesF
Sep 27, 2016 | Ovens
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
Where can i find instructions for cooking a turkey in a bella cucina oven roaster?
Here are the settings
Turkey, fresh, 10 - 14 lb, 350° F, 15 to 17 minutes / pound
A roster is a roster... when it comes to cooking they all cook by time and temp.
Time and temps can be found in this rival manual:
http://www.rivalproducts.com/manuals/MANUALS/RO180_43_56431310.PDF
Here are 2 recipie sources:
http://allrecipes.com//HowTo/how-to-cook-a-turkey/Detail.aspx
http://www.food.com/recipe/perfect-whole-turkey-in-an-electric-roaster-oven-339453
With any search engine (google, yahoo et al) use this search phrase for more recipies:
Roaster oven baked Turkey
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Crock Pots & Slow Cookers
How to adjust the toasting time on the preprogram
your better off going back to the factory setting. Call turbo chef but here you go this is how you re-program the thing. Remember i took the time to give you these directions. Please take the time to leave a review
PROGRAMMING
Edit Mode
The EDIT MODE enables the operator to manually alter
recipes and the cook cavity temperature (CCSP).
To access EDIT MODE:
1. Simultaneously press the UP and DOWN keys.
2. When prompted, enter the access code “9” and
then press the ENTER key.
Altering a Recipe
Most NGC (Tornado) oven models contain 128
unique recipes. The display shows two (2) pages each
with eight (8) recipe groups. Each recipe group contains
eight (8) recipes. See Figures 11 and 12.
To alter a recipe:
1. Enter the EDIT MODE (see page 16).
2. Enter the access code “9” and set the CCSP. The
screen displays the first set of eight (8) recipe
groups. To access the second set of eight (8)
recipe groups, press either the UP or DOWN key.
3. Select the recipe group that contains the individual
recipe you wish to alter. Select the recipe you
wish to alter by pressing the soft key corresponding
to the recipe item. Figures 11 and 12.
4. Use the UP and DOWN keys to navigate through
the recipe settings. Use the keypad and ENTER key
to alter any of the following three (3) parameters
(see Figure 13):
a. Cook time
Total duration of the cook cycle. Enter the
desired time and press ENTER.
b. IR element temperature (IRSP)
The temperature the lower radiant element
will maintain during the entire cook cycle.
Valid temperatures are between 500ºF (260ºC)
and 1150ºF (621ºC).
c. Events 1…6
Use the keypad and ENTER key to enter values
for % TIME, % AIR, and % WAV.
o Sum of % TIME for all events must = 100.
The operating system will not allow a
combination of events not equal to 100%.
o The % AIR parameter is valid between 10
and 100%.
o The % WAV (microwave) parameter is valid
between 0 and 100%.
5. After making changes, test the recipe by
pressing the TEST soft key. Once the oven has
warmed to the CC set point, press the TEST
soft key again to begin the test cook.
6. Once satisfied with the recipe, press SAVE to
permanently store changes.
7. Press the BACK key until exited from EDIT MODE.
Jan 14, 2010 | TurboChef TORNADO Electric Oven
Just moved to a house that has a old tappan convectionaire oven never worked one of these before how do i adjust the temperture so things dont just brown but cook throughout do i adjust it lower than the...
Sometimes, a good old fashion 'oven thermometer' work great to find the true oven temp. Then if it's off a few degrees, you can turn it up or down to get the right cooking temp you want.
Sep 24, 2009 | Ovens
Oven does not reach full temperature
Are you checking with a store bought thermometer or your recipe. If it is your recipe then ur thermostat might need a calibration or need to be changed completely if it is really off by more than 100 degrees. If it is 99 or less a simple calibration may just do it. If you have a steady hand. With your thermometer inside the oven and the door closed set at 350. Then take the oven knob off and take a small flat screw driver (really small). And insert it in the valve part where the knob was. With a flash light u can see the small screw. Turn it a hair at a time (1-2mm). Wait 20 minutes and see if the temp does rise. If not turn another hair. Repeat until 350 is reached. You must wait the 20-30 minutes for it to reach the temp. If all else fails changing the thermostat would be next. I do not recommend u do this alone. approx cost is: $400 - 500 front access, 500 - 600 rear access Good luck.
Sep 04, 2009 | Viking Ovens
Oven cooks at 400 plus degrees when set at 350 degrees
If your problem is temperature do this;
Press "options" Then press "6". Then press "3" to increase or "6" to decrease temp.
Then press "start" to end the calibration.
If you recently used self-cleaning you could have a thermal overload fuse problem.
Feb 23, 2009 | Whirlpool SB160PEE Gas Single Oven
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Nov 17, 2007 | Ovens
Amana ARGS7650SS Gas Kitchen Range Logo
169 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
