Question about Toshiba Satellite A100-S8111TD Notebook
I am on a wireless network with a strong internet connection but i still get an error message when trying to access IE8/Windows 7. when i run a diagnosis i get a message saying my computer is having trouble communicating with the dns. i know it is not a network issue because, i have two other laptops in the house and can surf the net with those computers just fine using the same network. what is the best way to solve my issue? PLEASE HELP!
  • Robert Stout
    Robert Stout May 11, 2010
    Some routers have a problem with W7s firewall, try turning it off and
    the connecting.
  • 177 Answers
I had the same issue and just installed Firefox. I downloaded the Mozzilla Firefox file from cnet.com, saved the installation file on a flash drive, and installed it on the problem computer and voila! Firefox is free and in some ways better than IE7 or IE8, so give it a try
http://download.cnet.com/mozilla-firefox/?tag=mncol
Posted on Apr 26, 2010
Im using a 2Wire Gateway DSL connected via ethernet to a Mac G4, I also have a laptop running windows vista and it has strong wi-fi connection, sending packets at optimal levels and speed. BUT Problem
Vista has a well known flaw of not allowing you to easily change access rights after selecting "public network" in the initial network connection screens. The easiest fix is to change the name of your wifi access point, reconnect, and be absolutely certain to select "home network" when the prompt comes up.
The best solution however is to ditch that crummy excuse for an operating system and upgrade to Windows 7 or 8.
Oct 05, 2014 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
I have windows 7 home prem and cannot connect says detects strong signal but limited access
Most likely, the access point is not connected to an internet gateway whatever that is at your place.
and since access points does not provide DHCP service by default (handing out IP information to connected clients), you get the limited access message.
In short, make sure the access point is connected to the router because the router is the once responsible for providing the DHCP service.
Feb 18, 2012 | ASUS WL-330 802.11b Wireless Access Point
Windows cannot connect to the wireless network
I would remove old cache wireless network connections. Example is when you once connect to a free wireless access at Library or Coffee Shop. Windows save all of these profiles and this will cause problems connecting. Then use Microsoft Wireless Troubleshooting resource:
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
Good luck
Dec 30, 2009 | Intel PRO/Wireless 3945ABG Network...
When I try to run the Dell Wireless Configuration Utility from the control panel I get the following error message:"The wireless network adapter could not be accessed. This application may have diminished...
Well Sir in this case i will advice you to disable the Dell Wireless Configuration Utility and instead use windows utility for a successful connection.
For disabling dell configuration utility follow these steps:-
1)Open dell Wlan utility , it will have five tabs at the top labeled wireless networks , link status , site monitor , diagnostics and information.
2)Click on wireless networks tab and uncheck the first option which says , "Let this tool manage your wireless network" then click ok or apply at the bottom right-hand side corner of the screen.
To Enable Windows Utility for Windows XP follow these steps:-
1)Open the Control Panel from the Start Menu.
2)From Control Panel click on network and internet connections and then open network connections from there.
3)Right-click Wireless Network Connection and choose Properties.
4)
Click on the Wireless Networks tab and if unchecked , then check the box for Use Windows to configure my wireless network settings. Then click OK.
5)Right-click on Wireless Network Connection, Select View Available Wireless Networks.
6)
This will lists all the available wireless networks in range. Select your network from the list and click Connect.
7)If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key(which is the password for the wireless network) and then click connect.
8)Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wireless.
This Link will guide you through the steps:-
http://kb.netgear.com/app/answers/detail/a_id/111/kw/wireless%20zero%20configuration/r_id/100109
Nov 24, 2009 | Computers & Internet
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; GTB6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30729) Timestamp:...
You seem to be using IE8 under Microsoft Vista ("NT 6.0").
Clear IE8's "browser cache" of all Temporary Internet Files.
Close IE8.
Open IE8.
Access FACEBOOK.
Try to access the web-pages for the 'In The Mafia' application.
Oct 22, 2009 | Microsoft Internet Explorer 8
Internet access from Windows Explorer 7
You might need to disable the dial-up connection. You might also need to enable the two network connections, sometimes they are disabled upon setup by default? What operating system are you running?
Apr 28, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
