Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Robo kleen stopped sucking - Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
  • 201 Answers
Mine will work for 10 minutes then stop but still drive around the pool
if i set it back in the garage till the next day
it will work again for 10 to 15 minutes
i took the motor apart and either oil and water escaped or was a type of oil that was in there
Posted on Jun 28, 2012
  • 640 Answers
Make sure that your filter bag is clean and free of obstructions. You will also want to check your impeller to be sure that nothing has jammed it. A jammed impeller actually occurs pretty frequently on these automatic pool cleaners.
Posted on Jul 28, 2010
4 Suggested Answers
thepool
  • 78 Answers
SOURCE: I have a robo-kleen pool cleaner which stops
If debris is entering the bag, it may be as simple as that. The bag is clogged. We typically recommend hand cleaning a pool before using an auto cleaner specifically for that problem. You might have to remove and clean the bag 50-75 times. Much easier to hand vac first. If no debris is getting into the bag before it stops, it could be a problem with the motor. we have seen them "short cycle" and require replacement. Rob
Posted on Apr 23, 2010
jharwell668
  • 640 Answers
SOURCE: Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Posted on Oct 07, 2010
jharwell668
  • 640 Answers
SOURCE: what is the output amps on robo kleen transformer
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
http://www.backyardcitypools.com/Pool-Cleaners-Automatic.htm
Posted on Oct 12, 2010
My robo kleen is moving but wont suck up the leaves and dirt
Possible blockage in the base where the leaves enter into the bag.
Jul 20, 2014 | Smartpool Robo Kleen
My robo kleen is oily
that is pool water mixing with some kind of lube
take off the metal plate and drain plug
let water drain out
Sep 05, 2013 | Smartpool Dolphin Robo - Kleen Above...
Robo kleen pool vaccum- not sucking- wheels move - prop on top turns very slow
if you hear a buzzing sound
there is water in the motor
if it drives ok, the power supply should be ok
try draining the water out of the small plate and plug shown
when you take out the filter bag
it will probably happen again
but a motor can be expensive to replace
Jul 31, 2012 | Smartpool Robo Kleen
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
What is the output amps on robo kleen transformer
Jul 03, 2010 | Smartpool Dolphin Robo - Kleen Above...
Jul 14, 2009 | Pool & Spa
Robo kleen stopped working, motor starts but it does not move
Hello, I think I had the same problem with mine : the filterpump worked, but robot didn't move. I opened it up and the problem seemed to be that the pin which locks up the gear wheel to the axle of the front wheels had broken into three pieces. We inserted a new pin (nail, screw etc) and the Robo kleen works just fine again. Maybe you should check this is also the problemwith yours. Good luck !
Apr 09, 2009 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
258 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
