Question about Maytag MGR5875QD CleanDesign Gas Kitchen Range
Maytag MGR5875QD stove problem
I have a maytag MGR5875QD gas range, somehow I can't start the oven anymore ?
Gas is on and the top burners work fine.
Clock display is ok but can't change time.
Can change time from 12 hr to 24 hr.
Can lock the display.
Can turn sabbat mode on/off.
all other commands don't respond, can somenody help me here????
Many thanks
  • winnegar Nov 15, 2008
    Did replacing the control unit fix the problem?
  • Anonymous Mar 26, 2014
    The clock works on display but the touch pad buttons do not work
  • Maytag Master
  • 2,651 Answers
Bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Posted on Mar 23, 2008
I have a Maytag 4-burner gas stove, MGR4452BDQ. The burners are fine but when I turn on the oven, the pilot light goes on and I can definitely smell gas but the burner/oven will not start/activate. Can I...
It sounds like the oven igniter is bad. You can repair this if you're handy, but be sure to kill the electricity to the range. Do a Google search for directions.
Mar 06, 2015 | Maytag Kitchen Ranges
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
2 of the 4 burners on my maytag gas stove aren't working. the oven is fine, just need to know where to light the pilot
Most newer Ranges don't have a pilot ... they have an electronic ignighter. When you first turn the burner on hear the spark going crack,crack
Feb 20, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
The electronic display went out on my gas range so I can not start the oven. I can still use the gas burners on the stove, but without the electrical panel I can not start the oven. I checked the wire...
This is often due to loose or corroded connections in the wiring.
Unplug the range.
Open the rear of the control panel.
Remove,then re-attach all wires on the control.
If you see any terminals corroded,clean them with a pencil eraser.
If this does not correct the problem,the clock must be replaced.
Dec 18, 2010 | Frigidaire FGFB75D Gas Kitchen Range
Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Nov 20, 2009 | Maytag PGR4410 Performa Gas Kitchen Range
Can't start oven. Stove top works fine. Maytag
top burner burnt out we replaced it with a new one and it still doesnt work please help? Ron
Jul 09, 2009 | Kitchen Ranges
Open Questions:
Maytag MGR5875QD CleanDesign Gas Kitchen Range Logo
562 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
