Its a MTX thunder 7500 12 with a split foam ring. Can I glue it together?
SOURCE: Schematic for MTX Blue Thunder Pro 752 amplifier
hello ..try this ...www.eserviceinfo.com...takes a bit of working out how to get them .when you do .you have to download bitzipper (these are a rar file)...then adobe 8 ..bitzipper can convert to a pdf flie so you can read them...hope you have some luck
SOURCE: i have a little rip on the subs ring
The little rip on the foam surround can be repaired easily with some pure silcone from a harware store. Make sure it's pure silicone, because the silicone mixtures may deteriorate the foam prematurely. Also, all you're really doing is plugging the hole that the rip makes so that air doesn't leak out and further damage the surround and also affect your sub's performance. You'll need to apply a thin to moderate coat of silicone to the rip, and make sure that some gets into the rip. Do NOT use globs or big lumps. You should apply some silicone to your finger, and carefully apply it to the area. Try not to get too much on the inside/backside of the rip. If you'd rather just get a replacement sub, you should be able to find the raw driver on eBay or at a local MTX dealer.
SOURCE: MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
SOURCE: mtx thunder 304 4ch red amp light comes on but no audio
if the lights on and there is no sound it's either a cd player issue or your rca issue or the inputs for rca's on the amp are no good. or you have your subs wired at a wrong load to your amp and it is in a constant protection to avoid burning up.
SOURCE: MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
