Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My Cub Cadet i1042 tractor shuts off when the blade is engaged. This happened after I ran over a ***** and/or stump. Every time I try to engage the blade the engine shuts off.
  • 3 Answers
Check for bent blade against deck housing.Possible you bent something on mowing deck,check all spindles and pulleys.You could have something hung on blade and making contact with deck. Rarely will the motor be hurt from hitting object on rider.
Posted on Apr 25, 2010
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Have a 3235 cub when blade engagement is pulled the blades don't always engage. Several attempts and the blades will engage. Switch or the clutch?
check the contacts most times the clutch contacts are loaded with grease and grass residue , simply cleaning the contacts should fix the problem
Sep 30, 2014 | Cub Cadet Garden
WHERE IS THE IGNITION FUSE ON A LT1046VT cUB CADET?
check seat safty or blade engagement safty one of those is bad
Aug 24, 2014 | Cub Cadet Garden
My cub cadet i1042 drive shaft won't engage ... The clutch or coupler is bad ???
hello reut... most of the cub cadets have a hydrostatic transmission. that said, keeping the transmission fluid full is key to good operation. Check the tranny fluid and add as much as you need to bring it to spot on full. joe
May 22, 2011 | Garden
I have a 1500 series Cub Cadet, 54 inch cut. I ran over a rope that wrapped around the blades shutting down the mower. I turned the mower off and removed the rope. I engage the PTO. I hear it click but...
put the rope back around the blades then go in reverse slowly, park the tractor where you found it prior to running the rope over, get off, shake your head a few times, then try it again, this time pick the rope up first! that should fix ya!
Aug 19, 2010 | Garden
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Jun 21, 2009 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
719 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
