Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VA720 on-off switch doesn't work.can it be replaced?, and how is this done?
  • 11,361 Answers
Are you sure you have broken switch, not failed power supply due to bad caps? Please see VA721 pictures (same chassis as 720)
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 25, 2010
Out of range box on my screen
Your PC video resoliton is set too high for the monitor to display, it shoulde be set to the native resoltion of this monitor: 1280 x 1024 @60Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.viewsonic.com.au/product_pdfs/lcd/17/E-VA720-10142003.pdf
Unless the monitor has the problem inside:
Oct 10, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Need ac adaptor for viewsonic lcd monitor VA720
Best is to approach the Viewsonic dealer and get the recommended adapter than to get one which is universal or matching.
Sep 26, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic va720 monitor flickers / goes a little dim. wiggling the power cord often helps.
then change the power cord...there may ba loose connection...or the pins int he cable is not getting full power
Dec 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
What voltage do i need for my ViewSonic VA720
Monitors and PCs (amongst other things) use a fairly standard power cable. You should not need to worry about the specifics as there is generally no transformer needed for a monitor.
Oct 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VA720 monitor has small blinking light, won't turn on
When turning on the computer we get analog auto save, and don't get as far as the desktop, how can I solve this problem
Debi
Missing cables and plugs
can you tell me your location so i can help you find the nearest store where you can buy the cable. or you may check this link http://www.amazon.com/Viewsonic-VA720-17-LCD-Monitor/dp/B000099SKU it sells for $9.99
Jun 16, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720
The VA720 I have has 4 screws from the back: 1 at each bottom corner and 2 in the middle lower at the base. Remove screws and carefully pry the front and back halves apart. They snap together. Usually working the bottom apart first is easiest.
Oct 08, 2006 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
136 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
