Question about Whirlpool WFW9600T Front Load Stacked Washer / Dryer
What does F20 on the display mean? The machine is making a noise and we can not turn it off!
    Scholar:
  • 126 Answers
IT IS POSSIBLE THE FLOW METER IS BAD OR THE CCU (ELECTRONIC CONTROL) IS READ A FALSE ERROR. OR THE WATER IS OFF TO THE WASHER. READ THIS ERROR CODE DESCRIPTION
If after 30 seconds not minimum 0.1l of water entered or maximum fi ll
time of 13 minutes is exceeded, the valves will be turned off and the
error code will be displayed. Press PAUSE/CANCEL twice to clear the
display.
Possible Causes/Procedure
If there is no water in the unit:
Make sure that both valves at the water source(s) are turned on
all the way.
Check for plugged or kinked inlet hoses or plugged screens in the
inlet valves.
Verify inlet valve operation.
If there is water in the unit:
Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
Unplug washer or disconnect power.
Verify there is not a siphon problem.
Verify wire harness connections to inlet valves, pressure switch,
fl ow meter, and Central Control Unit (CCU).
Check all hoses for possible leaks.
Plug in washer or reconnect power.
Verify pressure switch operation.
Verify fl ow meter operation by blowing air through the part and
measuring the resistance.
Verify CCU operation by running a Diagnostic test or any cycle.
Posted on Apr 24, 2010
What does F20 mean?
moz-screenshot.pngF20" on display
(Water Inlet Problem-no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Check the following:
1. Are water faucets completely turned on?
2. Are screens at inlet hose connection to washer
clogged?
3. Are water inlet hoses kinked?
4. Are water inlet hoses frozen?
if these issue's are ok you may want to contact a service company
Feb 26, 2011 | Washing Machines
Showing code F 20
f20 code means no water is entering the machine. make sure your water hoses are connected properly and that the water is turned on. could also be a problem with your pressure switch.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am recieving a F20 error message on a brand new whirlpool washers each time i use it. Its a Duet Steam.
F20 means water is not entering the machine at a sufficent rate, check water supply is connected correctly, turned on and hoses are not blocked or kinked or pinched.
Jan 14, 2011 | Whirlpool Washing Machines
F20 appires on the time display
The reason for "F 20" is that while there is "NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED." If after 30 seconds not minimum 0.1l of water entered or maximum fill time of 13 minutes is exceeded, the valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
The possible fix for this problem is:
If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
If there is water in the unit: Verify that the pressure switch hose is in good condition and
1. Unplug washer or disconnect power.
2. Verify there is not a siphon problem.
3. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Thank you
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the F20 message mean??????
Well the error F20 on display means (Water Inlet Problem, no water or insufficient water supply)
You can please check the following -
clogged? Are water inlet hoses kinked?
Post comments for further help or information..........
Good Luck!!
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine turns off and it shows f20 on display
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F20 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F20 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump. (You will need to remove the front lower panel to access the pump and filter)
• If the above does not correct the problem replace the pump.
Jan 17, 2010 | Kenmore Washing Machines
Getting F20.
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer has an error code f20...what does this means?
not enough water going to the machine..
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
water supply)
Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
Code F20 is appearing on me washing machine
Hi
Error F 20 means "No Water Detect" error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged.
2- Make sure water taps are working fine.
3- Check inlet hoses for kinks or clogs.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 26, 2009 | Kenmore HE2 Plus Front Load Washer
Open Questions:
Whirlpool WFW9600T Front Load Stacked Washer / Dryer Logo
Dan Webster
Dan Webster
Sal DeAngelo
