Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
New unit never used found the water filter cracked
New unit never used found the water filter cracked and water leaking , replaced with new filter, still have water leaking from somewhere
ant idea what the problem is
    Scholar:
  • 126 Answers
THE FILTER HOUSING MAY HAVE FROZE AND BROKE. MAY HAVE FROZE ON TIME IN SHIPPING. CALL ELECTROLUX THEY WILL SEND YOU THE PART AND A TECHNICIAN TO FIX IT. SO IT COULD BE REPAIRED IN ONE TRIP.
Posted on Apr 24, 2010
Testimonial: "good answer, water filter replaced. water is still collecting at the bottom of the ice box, the new water fiter is not leaking, ???"
  • BRIAN
    BRIAN Apr 25, 2010
    THE FILTER HOUSING IS WHAT THE FILTER GOES INTO. THAT IS WHAT I MEANT. AND THERE ARE TUBES THAT GO FROM THERE DOWN THE BACK. THE RESEVOIR MAY BE LEAKING BEHIND THE DRAWERS.
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
Model ATB1932 Water leaking
If you have water issues, odds are there must be a filter in the line somewhere in the unit. They are notorious for developing water leaks. Sometimes it's nothing more than a slightly loose jam nut, other time you wind up replacing the filter, (which is probably a good idea anyway,),and one or both of the fitting assemblies on the ends of the filter casing.
Apr 10, 2015 | Amana Refrigerators
Oil leak 2000 alero, just replaced plug, not it, leaked out all the oil after I drove it 20 miles, please help, could it be a gasket or what
Check the oil filter. The old gasket might be stuck on the engine (two gaskets stuck together), or the new gasket might be defective, misaligned or missing.
Nov 05, 2011 | 2000 Oldsmobile Alero
The water dispenser quit working,i can hear motor/unit turning,would a plugged refrig filter be part of problem?
Yes a clogged filter could indeed make the water dispenser not work...it too would affect the icemaker as well, is ice being made?? if yes icemaker is working yet no water being dispensed what ya need to check for is a cracked or broken line and instead of water is leaking out of it somewhere.
GENE
Sep 23, 2011 | Kenmore Side by Side Refrigerator
How do i change the filter in the amana my ice taste bab do i need to cut the water supply off to change the filter
Water filter is located in the upper right hand corner of the fresh food side.
Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
Sep 14, 2011 | Amana ASD 2624 Side by Side Refrigerator
I replaced my Whirlpool Ultraease Undersink Filtration filter model WHEEDF and th Filter 1 of the pair of filters leaks. I have applied teflon tape to the threaded pin of the mounting unit and the leaks...
I would shut water off and relieve pressure. Remove filter houseing and inspect rubber gasket on bath sides, clean it off and clean inside of cap where gasket sets and on top of housing. Make sure there are no rough spot on either surface. If there are you can smooth them out by using fine grit sandpaper,no coarser then 120 grit. Wipe all surfaces clean and apply 5-6 wraps of teflon tape on threads on filter housing. Before you put gasket back in place you can put a light coating of petroleum jelly,vaseiline or similar,on both sides of gasket. wipe off excess. Reinstall filter and housing. tighten securely. Turn water back on and check for leaks. If it still leaks you can tighten a little more. If it still leaks I would replace gasket. Hope this helps.Thanks
Nov 14, 2010 | Culligan Under Sink Water Filter
Hi, my insinkerator hot water dispenser is leaking from the bottom screw. It is a couple of years old. Moder SST
My unit is 3 1.2 tears old. It started to delay the flowing of hot water. Today I held the lever down until hot water came out but I noticed water leaking from inside the unit. I figured that the tank failed, and since it was over 3 years old I decided to open it up. What I found was that there is a plastic tube at the top of the unit that was very discolored and brittle which developed a crack. when I touched it it completely severed. I called the Insinkerator hotline at 1800-558-5700 and they told me that opening the unit voids the warranty. I said that it appears to be out of warranty and I needed just the plastic tube for repair. The per on on the phone said that as a one time courtesy that a new unit would be shipped to me free of charge and that I could install it myself or they will have a tech do it. I opted to do it myself. Hope this helps
Nov 05, 2010 | Emerson InSinkErator W-152 Point-Of-Use...
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
My Danze NSF 61 9 makes a loud howling noise ant almost any level of water flow. I have tried to adjust the water preasure but it does not help. Any ideas?
Brand new ours did not have this problem. It does now and I think the reason is the seam in the chrome over the handle is cracked and pressure leaks out causing the noise. It's now bad enough that it leaks also. Glue fixed both problems temporarly but its doing it again so I'm looking for a replacement. That's how I came across this post.
Jan 02, 2010 | Plumbing
Brand new filter pump leaking
If it is brand new and leaking, it sounds like your pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Jul 16, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
281 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
