Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer beeps intermittently when not operating
It's acting like someone pressed. the start button and then cancels itself. then does it again few minutes later. pressed clear several times, machine did it again. unplugged and replugged, machine did it again. then quiet for several hours, but recently beeped again.
    Scholar:
  • 126 Answers
YOU NEED A NEW ELECTRONIC CONTROL BOARD. I HAVE SEEN THIS MANY TIMES.
Posted on Apr 24, 2010
Intermittent Start (expanded explanation)
Lint will jam the start/run switch on the motor. Vacuum out the motor real good and check that the switch moves freely, and all the wires to it are plugged in good.
Nov 30, 2013 | Maytag Dryers
Intermittent start
Not a thermo fuse sound like motor is struggling.
May just need taken apart and cleaned
How do you ge codes on a electrolux front laod dryer?
* Wake the washer by pressing any button. * Wait 5 seconds. * Press and hold the Start and Pause/Cancel buttons simultaneously. * All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Aug 19, 2012 | Frigidaire AEQ7000EG Affinity Series...
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
Evaporator coils ice up after a few days and the refrigerator comparment only stops cooling. The unit is 2 years old. When removing the backing from the inside of the fridge and after thawing out the coil...
I have some information on your model and that would involve forced defrost by the service manual page 28 at bottom. How old is your Samsung? Forced Operation Function (Pull-down / Refrigerator Defrost / Refrigerator . Freezer-Defrost / Cancellation)
● This function enables a pull-down mode, a defrost mode for the refrigerator only, a defrost mode for the freezer and the
refrigerator at the same time, and a cancellation of this function.
● Press Power Freeze and Fridge Temp. buttons for 8 seconds simultaneously to get in the ready mode for a forced
operation.
● The display panel will return to normal after 20 seconds in the ready mode.
● At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
● Another way to cancel this function is to simply plug out and in the power cord.
1) Pull-down
1-1) At the ready mode, press any button once then the buzzer will beep (ON for 1/2 second and OFF for 1/2 second)
until this mode is cancelled.
1-2) At this pull-down mode, the compressor will start immediately (No 5 minute delay) and if the system is in the
defrost cycle, it will be cancelled right away.
note) If this pull-down mode begins right after the compressor was off, the compressor may not start to run due to an
overload condition.
1-3) At this mode, the compressor and freezer fan will operate continuously for 24 hours and the refrigerator fan will be
on and off according to the set temperature(34℉)
1-4) After 24 hour operation, the system will be cycled at -14℉ for the freezer and 34℉ for the refrigerator.
1-5) In order to cancel this mode at any time, select the next mode on the ready mode or power off the system.
2) Refrigerator Defrost / Refrigerator . Freezer-Defrost operation
2-1) At the pull-down mode, press any button again on the ready mode to begin the defrost cycle for the refrigerator.
2-2) The beep sound continues for 3 second at the beginning, then ON for 3/4 seconds and OFF for 1/4 second until
this mode cease.
2-3) After this operation, the system will come back to normal operation.
2-4) At this mode, press any button again on the ready mode to operate the defrost cycles for both compartments.
2-5) The beep sound continues for 3 seconds at that time, then ON for 1/4 second and OFF for 3/4 seconds until the
defrost operation cease.
3) Cancellation
3-1) At the R,F-Defrost mode, press ant button again on the ready mode to return to a normal operation.
3-2) Simply unplug the power cord, then plug it again to return to a normal operation.
Press both button for 8seconds at the same time Send maual in one moment, Thanks, Sea Breeze
Jan 20, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Jenn Air F7 error msg with incessant beeping
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Auto stop problem.
ck to see if wrinkle guard or some such feature is activated ..most dryers have a cool down followed by intermittant tumble without heat to reduce wrinkles
Nov 17, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Jul 16, 2007 | Kenmore 67082 Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
287 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
