Question about Sharp LC-26SD1E 26 in. LCD Television
LC37 GD 9E Flouresent Green outlining on all channels
How do i remove a ballast
ballast--- -usually a ballast transformer used in flouresent lights to turn 120 volts ac into 2000 or 3000 volts ac at a lower amperage. the ballast transformer has 4 nuts ,one at each corner for physical mounting .2 wires for the ac line cord and 4 wires for the flouresent tube. wires are connected together with wire nuts that can be pulled off the wires while unscrewing the wire nuts.
make a picture of what color wires go where,take wires off one at a time and make pictures. the wires are not interchangable and must go back exactly where they came off from or the unit will never work again.
many ballast transformers have an electrical diagram showing where the wires go. you may need a magnifing glass to see it well enough read it. Please study the diagram and understand it before you begin disassembly.
WARNING: You must make sure that the electriic cord is unplugged or the circuit breaker on the OFF POSITION
with the electricity on ,you can be electrocuted by either the 120 volts ac or the 3000 volts ac that means crash,burn and fry.
so de-energize first.
The replacement ballest must be rated for the wattage of the flouresent bulbs ,the length of the flouresent bulbs and the diameter of the flouresent bulbs. that are in the lighting fixture. the flouresent bulbs also have their own make and model numbers.the model numbers of the bulbs are standardized throughout the industry. The model number of the flouresnt bulbs that a ballast will work with is on thw ballest sticker, on the cardboard box and on the directions.the salesman in the flouresent ballest [lamp] section at home depot or lowes should also be able to help you.
Sep 08, 2012 | Hampton Bay 24002 Ceiling Fan
Green staticy looking outlines
What is model no and brand of your tv ?
How old is your TV?
Have you changed or replaced any parts recently ?
post back this details
SAM ANDERSON
Sep 23, 2008 | Televison & Video
A/c leaaks
you need to either add the green/yellow flouresent dye to the sytem with a refrigereant charge or use and ac leak detector its a hand held detector that can smell ac leaks
Jul 29, 2012 | 2003 Dodge Caravan
Green line about 2-3 inches wide on right side of screen
dasdgaiusgdausydgaysugdasyugd syugdauysgdauysgduyasgd yusagdsayugdausdsaydg sayugdayusgd ayu lkgkljgkglgkgkgkgkgkgkgjgmgjgmgjghfjdgfhgdhdfsbsfgshdgfcjfgdfjhfrgdhdgdhdgv hdgdjhdgdjhdgd jdgdjhd gjdgdjd g djd gd hd gdjd gd hjd gd hjd ghd jhd hgd d awdahwgdyhugdasbgduaysfd yaugduyadyasgidgsdt fsdgauysfdtasfdasbgdyafsiudtfasigy faiustfdaf tsafyuafuysdfayusfy drfasyfdyfasiuydfasyufadiu fysdfasyfdyafs ysafiuyafsuydfasiyudfuyafsiudy fasiuyfdyu afiyufsyudf aisuyfdayus fdiasuyfydfasiyudfayusfd iyuasfdyaufsyudfasiuyda56dr iayfduyfsay ufdayf dasdgpiushdaiudispudaisduapisdysaudy ayiouydasuydioautsdyoiusodyausdy osayuidysuoia ydayduiysuidayuiody osiuadyasudy uisdtauitsdausoidyhautdewuripwoery eiureiruw iuiuiuiuratiuiuiureai iuartu aeriutr ueaituaeriotuaporiutpoei utpreiutpieurtpaoierutaprtuapoitu uterituarepitu aerituaeir tuerutaiot uaiutaiorut aiertueirutpoeiturapioetuapoituerptu7rae8typer tiyte iuyrtya iye tiyaiyaerptyiraept iryatiyr iyaepoirtyapoirtyrapoiti yuioptruaiptypiureity areoiut rpaiutaeytpairtpeyrt part yartyp riyrt arey tytrapeiryt airytpoaiytriot aytpoiriyapo iypoiy poiy oiyypoiuy7tygtyrfgh tfhiujouyfrdftgbhui j iugtrdfyugbhihuhtuif uyhgiuy;ioj;lkjmlk;hujhi hiuohuguyuygyuufyt fuytfufyhguitfgiutyfuyighyuf yuuihufr ikifofgdifgdfgouiydfgoiugfidugpdfigudfpgi
Jan 25, 2011 | Mitsubishi LT-52133 52 in. LCD HDTV
Green tint on flash photographs
without color correction software on your pc, you may get green tint from the flouresent flash, or use a "filter" over your lens.More expensive digital cams correct for this, back in the 35mm days, I had color correction filters I interchanged during shooting under other than daylight conditions,i.e., incadescent; flourescent;ect.
Jan 27, 2010 | Moultrie MFH-DGS-100 Digital Camera
Channels gone off digibox in cork!!! any codes
00 -CE 19 2E 87 80 61 74 90
01 -AA 26 9E F2 E9 14 D1 AE
Apr 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Channels gone
these are telewest codes try them 00 = AA B7 D1 D9 CE 8E 83 AF
01 = A1 38 06 29 24 29 8D 2B
Need new codes for 'the box' for CHORUS or CHORUS CORK
5E 01
01
AA 26 9E F2 E9 14 D1 AE.
NEW CODES FOR CHORUS AS OF APRIL 3RD.HOPE THATS OK FOR YE.works in cork so that should be ok for u jim.enjoy all
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Sharp LC-26SD1E 26 in. LCD Television Logo
46 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
