Question about Starbucks Barista Burr Grinder
I have a Starbucks Barista Burr Grinder. When new, about two years ago, it worked well. Now it grinds only about 1 tablespoon of coffee in 30 seconds. I've cleaned it well around the burrs but it just won't do any better. I can'at see any obvious reason and I am reluctant to dismantle it completely unless I do it under specific advice.
  • Janet Kelly Apr 24, 2010
    It is what I would do myself given encouragement, so yes, the answer was helpful. Since bringing it to a repair shop could cost as much as a new one, taking it apart to clean it will either kill or cure.
    Thanks
    Guru:
  • 722 Answers
Jkelly482,
If this came with a warranty and is still under warranty, I would take it in to be repaired. If not, I would carefully take it apart and see if the inside is dirty. You'd be surprised the effect dust has on the simplist of motor parts.
If you do not feel comfortable doing this, have someone who is "mechanically inclined", or someone you trust to try and fix it. If you feel reluctant at all about taking it apart, I simply suggest using it until it doesn't work or just getting a new one.
I know this doesn't sound very "professional" or helpful, but when it comes to machines like this your options are really limited and it brings you to a process of elimination as to what would be best.
My "professional" opinion would be to simply (if applicable) replace the unit if it is no longer under warranty. Repair shops (without warranty) can be costly, even more so than purchasing a new unit, but you may be able to find someone who can do it for a fair price.
I would first suggest, howvever visiting Google and you should find a repair manual for this unit on thier.
Please let me know if you need any further assistance in this matter.
Cordially,
carsandcomps
Guru, Premium Expert @Fixya.com
Posted on Apr 24, 2010
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage...
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Apr 02, 2011 | Starbucks Barista Burr Grinder
I clean with rice and it grinds coffee beans. Then I have to grind moRE RICE TO GET IT TO GRIND COFFEE AGAIN
Instead of rice, fill container about half full with regular table sugar. Grind that for 10-20 seconds. You should not only get coffee flavored powdered sugar but the sugar will soak up the flavors from your grinder.
Then simply clean as you normally would. Works great!
Mar 19, 2011 | Starbucks Barista Burr Grinder
It says to "lift the
BURRS are the metal parts that grinds the coffee. There are 2 BURRS in the grinders, The upper burr is normally the one you adjust (Fine or coarse) and the lower or closer to the motor is the one turning during the grinding process.
Jan 25, 2011 | Starbucks Barista Burr Grinder
How to clean burrs
Easiest way run a tablespoon of rice through the grinder.
Apr 25, 2010 | Starbucks Barista Burr Grinder
Starbucks barista burr grinder: the motor runs but the beans won't grind
The drive mechanism from the motor to the burrs has failed in some way. It is necessary to disassemble the machine down to the basic components to determine the fault. Good luck!
Apr 06, 2010 | Starbucks Barista Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
May 14, 2008 | Starbucks Barista Burr Grinder
Was great for several years, but no longer grinds well
the best news is that the model is still on sale. http://www.starbucks.com nothing online about new burrs specifically but i am sure they will supply If you require a machine part, operational assistance or maintenance hints, please contact Warranty Services at 1-800-334-5553. Hope this helps :)
Nov 21, 2006 | Starbucks Barista Burr Grinder
Coffee Makers & Espresso Machines Logo
115 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
