Question about Sta Rite Sr200lp Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 200,000 Btu Propane Gas
Sta rite pool heater error r=5? Heater will not turn on.
  • 640 Answers
The users manual for these pool heaters has a chart that walks you through, step by step, a troubleshooting guide. That is the best way to find a solution to your problem because it asks pretty specific questions that you have to be looking at your heater to answer. Here is a link to the pdf file.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 16, 2010
  • 83 Answers
SOURCE: pool heater
If the heater fails to ignite after three attempts, the heater will automatically go into Lock Out. This is a safety feature on the heater.
Things for you to look at to see what is causing the problem are the display panel and diagnostic lights. When you turn on the heater, is it reading the correct water temp? If not, the Thermister has gone bad and will need to be replaced. When you try to start the heater, is there an Error Code displayed? Which of the Service Lights are coming on when the heater will not light? If it is the Serivce System, that is usually low flow of water. You may have a dirty filter, skimmer or pump basket full of debris, or a valve not completely open.
If the Service System light is the one coming on, then you will need to take off the top two halves of the heater and turn over the Display Panel. There are diagnostic lights on the back side of the panel. There may be a red light next to any of the following:
AGS, AFS, SFS, HLS, PS or THERMISTOR
If there is a red light next to one of these, then that is what has malfunctioned. If you need an Owner's Manual for the heater, you can find one online at the following link:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
Posted on Jul 08, 2009
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
  • 990 Answers
SOURCE: Sta-rite pool heater shuts down as soon as the
Between the two water pipes on the left side of the manifold is a two inch plug. When you take this plug out the thermal regulator assembly will come with it.It consists of "O" rings, a spring and what looks like a thermostat in a car. This is the probal bad part although it could be the spring also. You can get these parts seperatly or in a kit. If this is an older heater the kit is the way to go so you get all the nessary "O" rings and you will be covered on everything you need.
Posted on Dec 08, 2009
jharwell668
  • 640 Answers
SOURCE: Sta rite Maxe therm heater turns on by itself
These pool heaters have a very helpful and easy to follow chart in their users manual for problems such as this one. There are questions that you will need to answer that you cant answer unless you are looking at the heater. Below is a pdf version of the manual.
Posted on Aug 17, 2010
jharwell668
  • 640 Answers
SOURCE: shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
Posted on Aug 19, 2010
SR333LP pool heater continuously cycles ON/OFF, the fan stays on
The age and over all condition of the heater would help. Try removing the Thermal Reg and see if it smooths out. If the heater responds, replace the Thermal Reg with a new one.
Jun 11, 2017 | Sta Rite Sta-Rite Max-E-Therm High...
How to fix error code 6 on a sta-rite pool heater?
Try replacing the Temp sensor. You can not just jump it out, it needs to be repaced.
May 28, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Shows r 5 code when power is turned on. sta-rite
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta rite 400na gives error code 05 after about 30 seconds
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite Sr200lp Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 200,000 Btu Propane Gas Logo
1,056 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
