Question about LG WM2277H Front Load Washer
LG WM2277H Front Load Washer. The machine won't turn on. No codes. No nothing.
    Scholar:
  • 126 Answers
LG WM2277H Front Load Washer drain pump never stops
Could be the water pressure switch is faulty and/or the electronics control circuitry.
Suggest you called a qualified Technician to fix it. It will be worth it for many reasons.
Poppa
http://www.cdbaby.com/cd/poppamadison
Mar 23, 2012 | LG WM2277H Front Load Washer
LG WM2277H front load washer, how do I fully drain it so it can be stored in a Pod in the winter and moved to my new house?
It's a bit late, as I guess you have moved by now!
The best way to drain fully is to remove the outlet hose and let the machine lean backwards against an outside wall so that all water drains out.
Poppa
Oct 11, 2011 | LG WM2277H Front Load Washer
House fuse blew and now there is no power on LG WM2277H washing machine
Did you replace / reset fuse? Turn on washer again if it blows unplug it, unit has a dead short inside.
Dec 15, 2010 | LG WM2277H Front Load Washer
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
Drum bearing gone on my lg wm-16115fd
I would definitely not attempt this if you have no experience. Is is quite a lengthy process. Specialised tools are required. Discontinue using immediatly, as it will cause further damage to machine and property.
May 03, 2010 | LG WM2277H Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
What type of washer does the LG WM2277H take for the cold inlet hookup?
The water supply lines for the LG WM2277H are the same as almost all clothes washers sold in the US, which are standard garden hose threads, and use a standard garden hose washer.
Jun 17, 2009 | LG WM2277H Stainless Steel Front Load...
TE message. machine turns on but nothing else. I found out the message means a thermastor problem
Perhaps the error is "[-E" and it means the thermistor is out of error. Replacing it will correct the problem
Apr 27, 2009 | LG WM2277H Front Load Washer
LG WM2277H Front Load Washer Logo
192 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
