Question about Dryers
Maytag electric dryer model DE410' Dryer motor runs normally and freely; N0 HEAT is produced by the dryer element. electric heat element presumably is not working. Cold air is emitted from the exhaust. Thus clothes do not dry. I checked continuity of the element by checking the two leads/contacts of the heating coil. Continuity exists. Thus I believe the element is not burned out. There are three round, one inch diameter "relays" with two contacts each, visable in the cabinet. At least one has the nomenclature "purple" along with some part numbers. two are located in the lower front area of the cabinet. One is located on the housing of the dryer element and connected to the power leads of the element. Can you advise about getting element to work?
    President:
  • Dryers Master
  • 2,651 Answers
Check all of those "relays", htey are thermostats, monitoring you temps, they should all have continuity through them if not its bad. (temp jump it out) just to see the element glow. TEMPORARIly.. you CANNOT leave any jumped out you will damaged something. HOUSE FIRE. just wanted to instill the importance of not leaving jumped out
Posted on Mar 23, 2008
SOURCE:
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Maytag electric dryer de410 trouble shooting! How do I remove the cabinet?
There should be an element behind the spin drum,take cover off the back to undo drum.
Jul 26, 2014 | Maytag Dryers
Not getting hot
  1. There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  2. Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  3. Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itse
  4. When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  5. please comment on there by rating or voting how helpful.
Dec 23, 2010 | Whirlpool Dryers
My dryer won't heat. Maytag DE410
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day. Rating the solution is highly appreciated.
Jul 03, 2010 | Maytag Dryers
Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
I need detailed instructions on how to replace heating element of a Maytag DE410 electric dryer including diagrams...Dryer does not heat...
Very simple. Remove screws at the base and the front panel. The heater is on the bottom easily accessed. The re-string kit is way cheaper than the "mailbox" Start here:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 04, 2009 | Dryers
Dryers Logo
347 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
