Question about Maytag MMV4205 Microwave Oven
No power at display!
Thought I was using the kitchen time and set it for 30 minutes. came back later and seemed like heat coming from unit. could not stop timer. Eventually shut off by itself. Now have no power to the display. Circuit breaker did not trip.Maytag MMV4250AAS
  • Maytag Master
  • 9,047 Answers
You've probably destroyed your magnetron, and the magnetron thermostat.
This kind of abuse will not be covered under warranty.
It will likely run about $75 for a technician to visit the home, $75 to do the work, $75-90 for the magnetron, and about $15 for the thermostat.
You can locate a Maytag-authorized servicer at http://www.maytag.com
Posted on Apr 26, 2010
  • 3 Answers
Is unit totally dead, check overload that is near lamp at top of cabinet, the terminal at the overload was melted.
Posted on Sep 03, 2010
Frigidaire Microwave heats everything except for food
Your fianc? employed a surefire method of killing a microwave oven. A simple perusal of the manual would have revealed the recommended cleaning method.
Feb 26, 2017 | Microwave Ovens
Sometimes oven does not work. when ya hit start it just clicks - the screen looks normal for about 2seconds & then shows the clock time.
Sounds like is what's happening:
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back.
That would be a bad upper interlock switch and charred connector. If so, see:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Dec 11, 2012 | Panasonic NNSN797S Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Screen/ keypad seem to be locked
Sounds like the child lock has come on.
This addressed in your owner's manual. but if for some reason you don't have your owner's manual, you can download Maytag owner's manuals and installation instructions here.
Just enter your full model number.
If it's not the child lock,
I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work,leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Dec 23, 2008 | Maytag MMV1153A Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile microwave doesn't seem to be heating food real hot. during the last bag of popcorn we tried to pop it never even started popping it, and the microwave stopped and said on the screen...
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your sensor may have failed.
Nov 22, 2008 | Microwave Ovens
GE Spacemaker Microwave Clock inop
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shuts off about 10 - 30 after starting to heat an item. Display flashes PF. Which I figure is power failure. Unit is 5 months old and has very little use. Model WES1130DM1WW purchased at...
It should have a one year warranty, right? If so, Westinghouse should take care of it for you.
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 21, 2008 | Microwave Ovens
Numbers and light, but no power
It sounds like you have a bad control unit (the circuit board). We repair controllers nationwide for $39.995 in most cases, but if a part is needed which we cannot get, then it will need a new board. That can be ordered from http://www.vancebaldwin.com If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 06, 2007 | Sanyo EM-P672W Microwave Oven
Maytag MMV4205 Microwave Oven Logo
211 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
