Question about Refrigerators
I have a 3 door Whirlpool Gold fridge. The bottom
I have a 3 door Whirlpool Gold fridge. The bottom door (freezer) was left open about an inch or so over night and everything melted. We cleaned it all up and now the ice maker isn't working. Any thoughts?
    Scholar:
  • 126 Answers
ACTUALL FREEZER TEMPATURE MAY BE ABOVE 17 DEGREES. THEN THE ICE MAKER WILL NOT WORK. OR MOISTURE GOT IN TO THE HEAD OF THE ICE MAKER AND FROZE THE GEAR.
Posted on Apr 24, 2010
My whirlpool gold refrigerator will not cool. Only the bottom freezer works
Sometimes when the freezer door is cracked open a bit for too long, ice forms inside around the vent. I believe the fridge is cooled by the freezer air coming through that vent. Defrost the freezer completely, about 36 hours, and wipe it around till it is clean and dry. Then turn it back on and just wait... My Maytag fixed itself that way, and it took a few days to get cool to temp again..... Good Luck!
Feb 03, 2016 | Whirlpool Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Water under fridge sometimes
You may want to remove all the food, unplug your fridge, and the out the whole thing...melting the ice and cleaning out all the unwanted water. The drawer will be removable, and you can dry under it. Also check the overflow tray under the fridge, if there is one...it'll be full from all the melting.
Jan 24, 2014 | Whirlpool GX5FHTXVA Bottom Freezer French...
New fridge, freezer door left cracked open, looks ...
If new enough to still be under warranty, register and contact Whirlpool for repair.
Customer Care Service More Whirlpool
Feb 26, 2018 | Whirlpool ET1FTTXK Top Freezer...
Fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Apr 01, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Dec 17, 2008 | Whirlpool GB2SHDXP Bottom Freezer...
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Refrigerators Logo
280 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
