Question about Jenn-Air JGS8750 Gas Kitchen Range
I need 4 Jenn Air gas stove grates (12 3/4" X 10) - Jenn Air Expression (approximately 2001) - color: light gray.
    Scholar:
  • 126 Answers
My Jenn-Air range top will spark but no ignition. Gas does not seem to have enough pressure on that burner
Generally the issue with this is not that you don't have the correct pressure but the Burner top hat that displaces the gas is dirty.
Remove the metal rack to expose the burner itself. Make sure it's not been used recently to prevent a burn. Carefully lift the little burner cap off. This is the piece with all the holes in it the flames come from. They generally just sit on top. You will need a flashlight, know look in the little slits below the cap for cleaning material buildup. A tooth pick or a stiff bristle tooth brush can be used to clean these little slits.
The cleaning products used to clean stove tops tends to leave little trace amounts of surfactants that over time block these little slits and prevent the escaping gas to flow towards the ignitor preventing the burner from lighting.
Once you have this clean replace the top. Put the pan grate back on and try to relight the stove.
I am sure this should fix you issue. If it doesn't please let me know and I can give you some other tips to try.
DR Wilkins
Oct 16, 2013 | Jenn-Air Cooktops
Jenn-Air model svd48600. Gas stove top, electric oven. Why would the exhaust fan turn itself on whe either of the left burners is lit.
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the front...it should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set in...you'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
Dec 13, 2009 | Jenn-Air Kitchen Ranges
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
Jenn-Air JGR8855BDS Gas to propane conversion
propane is higher pressure than natural gas, there should be some orifices on the stove for the top burners, some have them near the top in a metal clip, some have them in a lower location, usually you can see them from the back of the stove. the oven and broiler may only need "tightened down", and the air blend will probably need adjusting for "flame color", you don't want yellow flame tips, good luck!
Jul 18, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Oven does not heat up
We may have found it -  google Maytag Gas and Electric Range Service Manual (1997 models to present) and save it as a PDF to your desk top.  Then print out the PDF pages # 18, 25 & 26, 52, 62 65 & 66.  Those pages sound exactly like the problem we're having, which sounds identical to the problem you're having. We now suspect the issue is the gas valve heater coil and the volts it needs for ignition.  Because without enough volts, the ignitor won't ignite (like, duh?).  The specific PDF page is # 66 in reference to the Glow Bar Operation item # 4. If we're right, we'll need to get three small parts, totaling about $60 in all.  Let's hope this is the solution!
Jul 09, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
2001-2002 GE Spectra XL44 Gas Range Parts search
it is your lucky day.....I have 4 grates/burners in gray .....make an offer before I put them on Ebay.
May 17, 2008 | Kitchen Ranges
Jenn-Air JGS8750 Gas Kitchen Range Logo
91 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
