Question about HP DeskJet 5850 InkJet Printer
Paper size Error message: The selected paper size is larger than the paper in the paper tray. Change either the paper or selection. This message appeared when switching from photo paper back to automatic paper selection.
  • 2 more comments
  • WACDCO Mar 23, 2008
    Horizontal and vertical sizes are set correct.
    I have never used any other size paper other than 8.5 X 11.0.
    I printed 23 pages of photographs on HP glossy photo paper- when I switched back to
    automatic paper- I received the error message.
    resetting did not help.
    sorry no luck.
    Incidentally the printer will print a test page with no problem on 8.5 x 11.0 paper.
  • WACDCO Mar 25, 2008
    Problem solved. Scrap of paper under the paper guides.
    Thank you everyone for proposing solutions.
    WACDCO
    Guru:
  • 1,894 Answers
Have you double checked to make sure you sent the horizontal and the vertical sizes right?
if yes then proceed
I had a similar problem in a different printer. I turned the paper in the tray 90 degrees. It looked totally wrong to me, but the printer stopped giving me errors & it printed correctly.
Posted on Mar 23, 2008
  • 4 more comments
  • dewan nafees ahmed Mar 23, 2008
    In the Properties page select the Paper Standards tab. select all of the standards you want in the paper selection list.
    If your paper source selection is tray, the A1 and A2 sizes will not be available if the tray cannot hold the A1 and A2 size sheets.
    but as per the information provide by HP
    Load a larger paper size or choose a smaller print size.
    so attempt all the possible solutions.
    any one of these will bring u luck
    thank you
    good luck
    http://h10025.www1.hp.com/ewfrf/wc/fastF...
  • dewan nafees ahmed Mar 24, 2008
    then i think you must change the settings from your printer software.
    that will be a final go
  • dewan nafees ahmed Mar 25, 2008
    thats nice to hear that the problem got solved.
    it will be more nice if you accept any solutions mentioned here.
    that will close this thread.
    thank you sir.
  • 655 Answers
Try to reset your printer it might fixed paper size problems:
To reset your device do the following steps.
  1. While the printer is on, remove the power cord from the back of the printer, wait 30 seconds, and then plug the power cord into the back of the printer.
  2. If the printer is not already on, turn it on by pushing the power button.
  3. Try printing again. If the issue is not resolved, continue to the next section.
If it did not fix your problem let me know, i will suggest another solution.
Thanks
Iqbal
  • 3,037 Answers
Try turning off the printer and computer and restarting both and see if this solves it and on the computer if this doesn't work, change the paper type in the printer's program
  • Benjamin Patri
    Benjamin Patri Mar 23, 2008
    let me know if this doesn't work
HOW TO FIX ERROR CODE 094-534
Make Sure the Paper Trays Are Configured With the Correct Paper Size, Type, and Color
To configure settings for Paper Trays 1 and 2
  1. Open the paper tray.
  2. Make sure that the required paper stock is loaded in the paper tray, and that the paper edge guides are adjusted properly to fit the size of the paper.
  3. Close the paper tray. The Printer Settings screen will be displayed on the Touch Screen.
  4. Select [Size], and then select the size of paper loaded in the tray. If this is a standard size paper, the correct size will be selected automatically if the paper guides are adjusted correctly. If necessary, select [Custom] to enter the paper size if the required size is not displayed and then enter the required X and Y values.
  5. Select [Save].
  6. Select [Type], and then select the type of paper loaded in the tray.
  7. Select [Color], and then select the color of paper loaded in the tray.
  8. Select [Confirm].
Nov 11, 2016 | Xerox ColorQube 9201P
Why do I keep getting an error message when I try to print on plain paper?
try to check your document paper size settings. if your document is in pdf format, try to unchecked the select paper size automatically but it will not respond since it is dependent on the paper size setting of the document.
Jul 17, 2014 | Ricoh Aficio SP C811DN-DL Printer
Depending on which paper tray you select, one of two error message is flashing on the readout: E70 or -A4. We cannot detect a paper jam. What do these codes mean and how do we correct it?
the error means that the size of the original does not match the size in the paper tray. select the tray you want use withe paper select key then make your copies
Feb 14, 2011 | Copystar CS-1500 Copier
I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Jan 16, 2011 | Xerox Office Equipment & Supplies
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
Lexmark T630 error message: Change MP Feeder
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Sep 15, 2009 | Lexmark T630 Laser Printer
Load paper error message when using legal paper. Paper tray is full and still get message. Loaded feeder tray and got clear paper jam. Yet letter size paper worked in the paper tray.
you have to program the paper size anytime you change the size of paper you use in a lot of panasonic machines. This is done through the
function" feature... go intofunction... general settings...scroll down to key operator mode...the code will be "00000000" (8- 0's) and it will be in one of the first screens up
Jul 06, 2009 | Panasonic Workio DP-1820E Copier
Error message unable to print
1.The printer is asking you to manualy load the right size paper.
source tray possibly tray 1
2. The printer has finished printing the first side of a manual-duplexed job and is waiting for the pages to be reloaded so it can print the second side. Reload the pages.
3.you are trying to print to the source (tray) and there is no paper in the selected tray. laod paper trays.
4. The print image is larger than size of paper in the tray. Load the right size paper. Press go Button
Jan 02, 2009 | HP LaserJet 2550L Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Paper Size Error
Hi there check that the printer properties have not been changed.
  • Click Start
  • Select Printers and Faxes
  • Right hand click on printer icon
  • Select Printing preferences
  • Check that the paper size matches that you have got in the tray
  • OK and exit and test
If the above doesn't work try the following
  • Open MS Word
  • Open the document that you are having problems with
  • Click File
  • Select Page Setup
  • Check that Paper Size is correct
  • OK close and test.
This is normally a driver issue as the paper tray on the printer doesn't know what size paper is in it until you tell it from the driver.
Hope this works for you
Thanks J
Dec 27, 2007 | HP DeskJet 5650 InkJet Printer
HP DeskJet 5850 InkJet Printer Logo
112 people viewed this question
Seeker5211
Seeker5211
