Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water keeps dripping during entire cycle even after its done washing
    Scholar:
  • 126 Answers
SOUNDS LIKE YOU HAVE A BAD WATER VALVE.
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 24, 2010
Water keeps dripping into machine when washing is done
Water entering the machine when it is off likely means you have a failed solenoid on the water inlet valve. It is possible that low water pressure could cause it but if your machine fills normally during use, then the water inlet valve needs to be replaced. It is a simple job if you would like instructions.
Mar 06, 2015 | Washing Machines
My washer will drip water back in the tub after complete washing is finished Why Help
If the water is dripping in from the area where it normally fills for a wash cycle, then you probably have a problem with the water valve. You can open them up to see if debris has made its way into the valve, but they normally are not real expensive and it may just be easier and less hassle to just replace the entire valve. Hope this helps!
Feb 18, 2015 | Maytag Washing Machines
Kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
Oct 29, 2013 | Refrigerators
Water leaks into my smartdrive 058 machine throught the wash cycle and when the machine is switched off.
you need a new water valve for the unit. The solenoid is getting stuck in the open position (at least partially) and allowing water to continue to come through even after the water valve is no longer energized. This can be caused by normal wear and tear or sediment from your pipes getting stuck in the valve. This is especially true if you have well water or have recently had any plumbing work done in your house like a new hot water heater or something like that installed.
Nov 16, 2012 | Fisher and Paykel Washing Machines
Frigidaire gallery front load washer dripping sound
With any front load machine manufacturers suggest to leave the door open after cycles to help evaporate the water - this is even done in top loading machines nowadays. Also clean the unit with bleach water and rinse in high temp water cycles.
Aug 12, 2012 | Frigidaire GLTF1670A Front Load Washer
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
The washer only fills halfway up during rinse cycle only, even on high water setting. it fill completely during the wash cycle.
Has it always done this or just recently? Some washers have lower rinse fills then spray the water on the clothes as it goes through its cycle.
Sep 24, 2011 | Estate Washing Machines
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
