Question about Princeton Digital VL1918 Monitor
Princeton Monitor VL1917 - No Power
I have a Princeton VL1917 monitor. I hadn't used it for a while and now I want to sell it to a friend, but the power light doesn't come on. The AC adapter has a green led on it and that turns on, but the green led light on the monitor doesn't turn on. Hoping it's a quick fix.... thanks.
    Novelist:
  • 138 Answers
This is the way how to examine what's wrong with your LCD monitors. After you turned your pc on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
SOURCE:
Service Manual with Schematics for Princeton VL1916 LCD Monitor
this issue might not be because of your Monitor. Anyway, I can only provide manual to this legacy product of princeton if you want...
Sep 06, 2007 | Princeton Digital VL1916 19" LCD Monitor
Princeton VL173 monitor (12V 4A) only stays on momentarily
Sounds as if you may be dealing with a power supply (AC Adapater) issue. I had one go out on my Princeton VL173. I wasn't sure whether it was the PS or the display that went back. One day it just went black.
I had a hard time trying to find a replacement power supply. Out of desperation I used an old AC adapter (power supply) from an old HP printer that died. It had the same plug, and the power output profile was very nearly identical.Oddly enough, it worked! It has been trouble free for many months now. And it fit within my budget. (free!)
If the power output profile on the HP adapter was not so very close -- almost identical -- I'm not sure I would have done it. Also, it may be that the two power supplies are not intended to be interchanged. But I can tell you that from my experience it has worked out great so far, and it has been a lot of daily use for a long time.
I hope this helps.
Steve
Dec 18, 2010 | Princeton Digital VL173 Monitor
Princeton Digital VL1917 Monitor no power no display
Very common problem, look for bad caps with leaking/bulging tops as shown in my pictures:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 09, 2010 | Princeton Digital VL1918 Monitor
I have the princeton VL193 monitor. Its blank, no power light
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 14, 2010 | Princeton Digital VL1916 19" LCD Monitor
VL1716 Monitor screen black
they are using java and possibly dhtml scripts, your browser may not work properly with their site, but this is the link
http://www.sonyrewards.com/en/home/base/?ref=http%3A//www.sony.com/index.php
Aug 20, 2009 | Princeton Digital LCD17D (Graphite) 17 in....
Princeton Digital VL1918 Monitor Logo
259 people viewed this question
Top Princeton Digital Computers & Internet Experts
Ekse
Eric Rotmil
Eric Rotmil
Sr. Pelo
Sr. Pelo
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
