Question about Pioneer GEX-P920XM Satellite Radio Receiver
The p920xm reciever cut outs then quits
My xm radio works fine for a little bit and then starts cutting out and eventually has no sound. It still has a display and changes stations.
3 Suggested Answers
SOURCE: No XM Audio, no fault indication
Buss cable is plugged into the wrong connector on the GEX-P920XM. The installation manual is not clearly written, the figure in the manual is correct.
Posted on Feb 25, 2007
SOURCE: I have just installed a GEX-P920XM on a
make sure the bus cable is in the correct plug on the reciever
Posted on Apr 24, 2010
I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone...
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
Jul 17, 2014 | Audio Players & Recorders
Skyfi3 freezes up on checking media
common problem! Press the volume UP and the Power button at the same time and it will go off. Go to the Delphi/XM website and upload/download the latest FIRMWARE and upgrade it. Then, call the 800 phone number for Delphi and they will tell you a secret master reset you have to do once or twice, and it will cut down the number of lockups during checking media by quite a bit. Also, do not use a Micro SD card larger than 2MB as well. Good luck, and let me know how it goes for you.
Aug 06, 2010 | Delphi SKYFi3 XM Radio Receiver
Not getting xm tuner slection anymore. Just get
make sure you have all the connectors where they should go
Jun 01, 2010 | Pioneer GEX-P920XM Satellite Radio...
No sound comming from the left side speakers in my 04 Envoy XUV.
first> road vibrations can cause cable connections to come loose so you can start by taking out your radio and making sure all of the questions in the back are connected as they should be.
Second> if this doesnt seem to work then the next step is to check the wires going to the speakers that arnt working (this will b quite a job, but if you can do it, it will save u quite a bit of money) .. checking the wires your checking for >bad connection to the speakers >cuts in the wire or if any part of the wire is touchin any other metal object
Was This Helpful ?
May 29, 2009 | 2004 GMC Envoy
XM Radio
My XM just recently started to cut out in certain locations that had no problem before. It seems to be getting a good signal the screen display does not cut out. I lose volume and get static just in certain spots. Anyone know where I should start looking for a fix.
Jun 26, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Sound cuts out.
I had the same issue with the front right speaker randomly cutting out. Thought it was a loose solder joint however upon taking it apart i found that something near the back panel was shorting out. While apart i found that wiggling the rear panel would cut in and out the speaker. Also the fan would turn on when the speaker worked, which until i took it apart i didn't know it had a fan. I removed the back panel by taking out several screw the hold the cable plug-ins. once the panel was out i insulated it with electrical tape then used a utility knife to cut out all the cable connector holes. I also took out a couple screws on the main board so i could lift it a bit from the back and ran electrical tape over the solder point for the speaker connectors. Put it back together and haven't had any cut out's since. I now notice that the fan now runs all the time exept when i press mute. I also hear a single tap noise for a second when i mute or turn off the receiver. I can certainly put up with that though. Hope this helps someone else, I put up with the speakers cutting out for 6 months before i got around to taking it apart. Also those bannana plugs are a rip off, I went to future shop to buy them and couldn't beleive they were 25.00 for two pair. That would mean it would cost me 75.00 to do my 5 speakers. Thats more than i paid for my dvd player. anyhow i didn't buy them and just used bullet connectors, pack of 10 for less than 5.00, not made of gold but they work fine.
Aug 08, 2007 | Pioneer VSX-816-K/S Receiver
Loss of XM signal
The problem is amazingly simple.
The red wire goes to your ignition so it turns the radio off when you power down your car so as not to discharge the battery.
The YELLOW wire is usually your memory and it connects to the power side of your fuse box (anywhere will do as long as it's powered when the car is off completely). Occasionally this wire is blue but it's rare.
This wire draws a tiny little bit of power so your stereo doesn't 'forget' your station settings etc.
BTW Pioneer is one of my favourites :)
Apr 16, 2017 | XM Radio (XMP6000)
Sep 22, 2006 | Pioneer GEX-P920XM Satellite Radio...
Pioneer GEX-P920XM Satellite Radio Receiver Logo
88 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
