Question about HP Compaq Presario v3000z Notebook
Laptop switches off by itself
My compaq V3000 keeps switching off by itself after using it for a while. as of now i think it is because of the heat. but even after about half an hour it shuts by itself.
  • mereeta Mar 24, 2008
    thanks...wil try the cleaning process...i am not a very tech savy person..but something tells me its got to do wit the heating..and it switches off while i am working on it..not when its idle..thanks a lot both u guys...wil let u know how it goes.and if it doesn't then i know where to come for help..:-)
    Master:
  • 474 Answers
This is usually a heating problem, try using compressed air and spraying the vents and cpu heatsink fan.
Do this while its off. If its really full of dust and junk, you may have to take it apart and clean it out. The processor usually has a heat sink and a fan that displaces air. Check all these. Also make sure the heatsink is screwed down properly, it may not be making good contact onto the CPU.
Also, note: When using your laptop, its good to have it on a flat surface that can help to displace heat from the bottom of the laptop, dont use it on carpet or in your lap.
Is it turning off with no warning? and is it when your doing something or just when its left idle? If its idel when it does this, it could be your power settings. You may want to check those.
Posted on Mar 23, 2008
    Genius:
  • 1,913 Answers
Check your ram memory.
scan your pc with quick heal ,avast and symantec with update definition.
I'm using compaq persario v3000..i lost functioning of my wireless connection button...it is in off mode.. are ther any shortcuts to on it??
if you look at the keyboard their is switch with which you can turn on the wireless.
it looks like a vertical line with fringws on the top a telephone tower type symbol
Aug 11, 2011 | Computers & Internet
Facing Problem with compac v3000 no display
First see if any monitor will work, plugged in at back? If works, check, just isn't been LCD monitor has been disabled by a key command, then if NOT work, it is probably Video card. OR actual LCD, OR the LCD power supply and/or Inverter? may also be bad connection to MB? Or Broken ribbon in lid, or case. Faulty sleep open/close LCD switch? Try those.
Mar 02, 2010 | Compaq Presario 2580US Notebook
Freezes up and turns itself off
its is related to heat why don't u contact youw service centre...while using laptops give them a space for air to flow and use them in low dust area
May 20, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq v3000 laptop no display led is glowing Compaq Presario v3000 no display, just led light wearing and fan is on.
Try using the function key for your display options
You should see a key related to your function key, generally a different color then the rest, labeled (F, Fun, FN, etc...) then look for a CRT/LCD, or LCD, or a symbol of a rounded square, or something resembling a monitor or screen.
Hold Fn and press that button, give it a few seconds. It should switch.
You can also hold a flash light up to the screen and see if there's any image, if this is the case then parts need to be replaced.
If you have any more questions please let us know. If this information has been helpful, please take a moment to rate the solution. Thank you.
Apr 23, 2009 | HP Compaq Presario V3000T Notebook
COMPAQ V3000 AMD SEMPRON COPROCESSOR PROBLEM
If your v3000 only shows leds but no video you need to replace your GPU(graphics processor) Hp has an active recall for this problem for certains models, you can check if your v3000 qualyfing for this recall in ww.hp.com
The manner that we resolve this issue:
you need to remove your MoBo completely from your laptop, remove your heatsink and coller from your Cpu/Gpu, with a heat gun(similar to hair dryer) reheat your gpu, this will cause that your gpu re-soldering and will function very well.
If you think this is so hard to you you can send your laptop to: VCRTECH
10001 buckwood Av. 79925 El Paso Tx
We repair your laptop in 2-3 business days and we charge $80 usd for this repair.
Thanks
vcrtech
www.vcrtech.com
support@vcrtech.com
vcrtech@hotmail.com
Please give me your feedback
Apr 21, 2009 | HP Compaq Presario V3000T Notebook
I need lan driver for v3000 laptop
There are several versions of a Presario V3000, nevertheless, pls try here and select your model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 11, 2008 | Computers & Internet
COMPAQ V 3000
THERE MIGHT BE A PROBLEM WITH THE PROBLEM WITH THE POWER SUPPLY .. ELSE THE PROCESSOR MIGHT BE IN A STATE OF HANG UP ... NEEDS PROCESSOR REPROGRAMMING . 3-4 HOUR JOB AT THE SERVICE CENTER
Aug 19, 2008 | HP Compaq Presario v3000z Notebook
Volume control problem
i have no loaded sound driver in my laptop 'compaq presario V3000', i need a software of media device for free downloading
May 29, 2008 | Compaq Audio card Sound Card
HP Compaq Presario v3000z Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
