Question about Whirlpool GGW9250PL Gas Dryer
My whirlpool (ggw9250pw3) gas dryer loud squeak
My whirlpool (ggw9250pw3) gas dryer is making a very loud squeak like a bearing is bad or a brake is stuck on, baout 4 years old.
  • sultan132 Apr 24, 2010
    computer is very slow
    Scholar:
  • 126 Answers
THIS SOUNDS LIKE AN IDLER PULLEY THAT KEEPS THE TENSION ON THE BELT. SECOND CHOICE WOULD BE DRUM ROLLERS.
Posted on Apr 24, 2010
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Replace belt on whirlpool gas dryer ggw9250pw3
Below is a video with step by step instructions for replacing the drive belt on a front loading whirlpool gas dryer. Best of luck!
Greg
Apr 24, 2012 | Whirlpool GEW9250 Electric Dryer
Our ggw9250pw3 Whirlpool Dryer has begun making an aweful grinding noise and a clanging sound. It still drys and the drum turns
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | Dryers
Whirlpool LEW0050PQ electric dryer makes a noise.
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore 417.84042500 stackable gas dryer. Started
It sounds as if the bearings in the dryer have gone bad. The same thing happened to my dryer.
Oct 22, 2009 | Kenmore Dryers
Dryer turns and heats, but makes a very loud squeaking (or should I say, SCREECHING) noise. The heavier the load, the louder the squeaking.
Does it sound like a belt ?
Or does it sound like metal ?
Might need to replace the drive belt..
Or - it could be the bearings..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Jan 13, 2009 | Dryers
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
528 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
