Question about HP LaserJet 1100 Printer
Paper feeder will only draw in paper part way
    Sergeant:
  • 313 Answers
You have to replace the Paper Feed Roll Assembly
Posted on Apr 26, 2010
Paper keeps jamming
Where document feeder or hot area (fusing unit) or paper draw?
Jun 23, 2014 | Minolta DiALTA Di183 Copier
Konica minolta c 35 keep saying missfeed was detected
Sir/Mam, Which paper draw or is it the bypass tray? Or the document feeder? Are you using the correct paper type.. Clean the rollers with some alcohol. Two per draw. two rollers for the docfeeder
Jan 13, 2014 | Minolta Di251 All-In-One Printer
Missalignement problem! Printing or copy-ing, my dialta di520 is not printing in center (off centered)... is starting to print at 7-8 mm from one long side and 6-7 from the short one. If i print / copy a...
First is this a problem with just one draw? Move to a different draw. lets eliminate the draws and or the by pass tray. Does this happen when using the Document feeder. Place the original on the big glass does it happen then? Secondly have you the correct size paper are you using metric size paper and the machine thinks it is inch size paper. Have to let the copier know what country it is in. Does this happen when you print or when you copy? Check the guides in all the paper draws they have to be snug up against the paper
Aug 23, 2013 | Minolta DiALTA Di520 Laser Printer
The paper will not feed properly into my mx320 canon printer. It pulls the paper in on the left side but not the right side. I can see no paper stuck anywhere on the rollers. I have removed and replaced...
The mX320 being a rear sheet feeder model can suffer the problem of something falling into the feeder and causing the paper to jam on entry.
To find what has fallen in your will need to gently pull back the fed paper and look at its leading edge. This will show a heavy "Nick" in the edge. observe where the nick is in relation to where the paper is fed and that will indicate where the obstruction is in the feeder. Use a bent paper clip (L shaped) and see if you can feel and dislodge the culprit. Remove the ink cartridges and turn the machine upside down and give it a good shake. hopefull the drawing pin/paper clip/notice board pin will fall out and the world will be at peace once more.
Good luck.
Aug 07, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Error 2 paper out but not
Does that printer feed from two ends -- a tray and a feeder at the back? If so, make sure your program is set up to draw the paper from the correct tray, or else put your paper in on the other side.
May 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Top paper feeder roller rotates but does not draw in the paper
There is no replacement rollers available so, printer needs to be replaced.
Apr 08, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Canon L75 draws all the paper at once
Try cleaning the pickup and separation rollers and /or pad inside the document feeder. If this doesnot help they need to be replaced contact your local canon dealer for help with parts.
Nov 28, 2009 | Canon FaxPhone L75 Plain Paper Laser
Paper feeder
clean the rubber roller with alcohol this roller gets dirty all the time...this feeds the paper...im trying to upload my drawing..to guide you..
Feb 09, 2008 | Canon S520 InkJet Photo Printer
Auto-Feeder Does not feed paper evenly
There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Lexmart C524
The printer may be trying to draw paper from a source other than the paper tray. Many printers have a hatch or slot in the front or on the side in which one can load non-standard paper sizes and envelopes. It may be trying to print there. Try to locate this place and put a few pieces of paper in there.
Sep 13, 2006 | Lexmark C524 Laser Printer
HP LaserJet 1100 Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
