Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Wont pick up
The cylinder where the brushes are isn't turning.
    Problem Solver:
  • 4 Answers
Change belt
Posted on Apr 25, 2010
How to replace vacum belt on new Sharp EC-TU5306
remove bottom plate and pull brush roll out. buy a replacement belt and follow procedure to put back on. sounds like you have a clogged hose also.
Jan 29, 2013 | Sharp EC-TU5306 Bagged Upright Vacuum
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
Why does my vacuum leave a trail of hair on my floors when it's being pulled backward but suction up fine when it's going forward?
It is because the belt is worn and stretched. when you go forward there isn' t as much resistance and the brush can turn and pick up, but when you go back there is more resistance and doesn't pick up. You simply need to replace the belt. Here is the belt you need:
Eureka Boss 5849 Belts
May 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
The belt broke and after putting on new belt I dicscovered the cylinder with the brushes attached wasn't turning. After I finally got the cylinder to turn it makes a very very loud noise and also now it...
Check the cylinder with brushes does not have hair or carpet fibers causing it to bind. With the belt removed the brush should turn freely and fairly easy. The original belt probably broke because of this. You may have to fully dis-assemble the head of the vacuum to clean the entire brush assembly.
Sep 19, 2009 | Dirt Devil Vacuums
Motor wont turn on.I checked the switch and I think it is working.motor turns on if a put direct power to it.`but it smokes at the brushes. can you help?
This sounds like either the belt isn`t on right or the brush is not slotted in the vacuum right remove the plastic or metal cover from the bottom and check by inspecting the belts ability to easly turn the brush rod check with your hands DO NOT turn vacuum on while plate cover is off it could fly off and cause injury.
Sep 05, 2009 | Kirby G4 Bagged Upright Vacuum
It turns on but the spinner underneath wont work now
Turn the vacuum so the bottom is facing up..
Take out the scews in the plate that surounds the brush and take it off..
The belt should be firmly on the brush and the motor..
If the belt has come off the motor - pull out the side of the brush that the belt connects to.. Put the belt back on the motor post and the brush.. It might be a tad tough going back in because the belt should have a little tension..
Once the belt is on and brush in place - put plate back on..
Hope this helps ;o)
Jul 15, 2009 | Bissell 3576 CleanView II Bagless Upright...
My Bissel 3750E vacuum won't pick up.
see if the brushes are turning if not // broken belt
Oct 20, 2008 | Bissell 3750 Lift Off Bagless Upright...
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
114 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
