Question about Hit Thomas and Friends TrackMaster R/C - Percy
How do I cange Trackmaster Percy's battery
I have no idea where they are or how to change the battery in Track MAster Percy. I opened the 2 screws on the bottom and found 2 silver cylinyers and 1 flat rectangular something. I have a very unhappy grandson right now
In the early model trains - Just by the middle wheel there are plastic brackets that lock the top in to open squeeze on both sides above the wheels to move the brackets in and pull the top up - This will open the top and then you can replace the battery Note my wife helped me to figure this out as I took all the screws out as well
Posted on May 30, 2010
  • 2 more comments
  • jeparker49 Dec 15, 2010
    I wish I'd found this solution before I pulled out all my hair ... my wife bought this train, and threw away the box it came in (which undoubtedly had the instructions on inserting the 1 AA battery required)!
  • missmarymink Jan 02, 2011
    We took all the screws off and some metal cylinders came out. Now the train won't work! Do you know how to put them back in?
  • Sheralyn Lime
    Sheralyn Lime Dec 29, 2011
    here is how the magnets go back in after trying to replace the batteries and opening wrong compartment. Happens to everyone, well almost everyone. Also this is how to replace batteries first then how to put magnets back.
  • Sheralyn Lime
    http://www.fixya.com/support/t8536339-ca...
Opened the wrong compartment to change the battery and the gears fell out. I need a picture of gears to get it back together.
This is Bertie the bus. It stopped working so I took it apart. The Philips head (criss-cross) screw gives access to the battery. You're not supposed to take out the screws with triangular socket heads. If you do everything falls apart and you need an engineering degree to know how to put things right.
This battery holder is clear plastic, instead of black, so I can see what is happening after assembly. The red wire broke off the motor while I was looking at it so I had to resolder it. The red plate on the upper part swivels, it has an arm that holds the clutch plates together when the switch is on. The long white arm at the upper end of the gear assembly should fit into the slot of the red swivelling plate. I think it is supposed to be a noise-maker.
Bertie is supposed to go on the road, not the track and there is a plunger that cuts out the power when it is on a wooden track. This stopped working so I jumpered it to be always on.
Good luck.
Aug 25, 2011 | Seth Thomas Thomas & Friends Percy Train...
Just bought the ghostly percy and cant open to put a batty in it help
THE BATTERY SHOULD GO IN THE BOTTOM OF THE TOY.YOU MAY NEED A REAL SMALL SCREWDRIVER TO OPEN IT.
Feb 08, 2011 | Seth Thomas Thomas & Friends Percy Train...
Where does Stanley the train's battery go
There are apparently 2 different models of the Stanley train for the Trackmaster. One comes with a tar car and one is by itself. If you have the one with the tar car, the battery goes in that. If you have the one that comes solo, then you have to flip it over and in the middle of the bottom is a small screw that you have to unscrew and remove the middle wheels to take the top off. Once you have the top off, the battery is located there. I hope this helps.
Jan 22, 2011 | Seth Thomas Thomas & Friends Percy Train...
I through away directions by mistake. How do I put the battery in Percy. Thanks.
My child has a similar train but it is a Thomas instead of a Percy. There is probably a screw on the bottom. My son's train has three screws and the one in the middle (+) is the one that opens the train so I can put a battery in it.
Nov 29, 2010 | Seth Thomas Thomas & Friends Percy Train...
Thomas & Friends, Talking Percy doesn't move.
It has to be on the track to work for some reason. Turn it on, put on the track and press the button on that makes it talk.
I have to say I am pretty mad at fisher price for this one. The box says 3 AAA's included, when you open the box though you find out that they are "just for demonstration". So back to the store for batteries. Get the batteries changed, and then it doesn't work. Back to the store to exchange, and then find out it does work.
Jan 27, 2010 | Hit Thomas and Friends TrackMaster R/C -...
Needs new batters how to open razor 7526
Opening a Braun 7000 Series Shaver
1) Find a thin metal object with no sharp edges (such as a nail file). Use your thumb and pull on the bottom end cord socket part, enough to cause a gap between it and the back shell. Insert the metal object into the gap in the center of the part. THEN pry it off. If you use a regular screw driver, you will likely cause gouges in the plastic. And the best leverage is in the center.
2) The silver side parts are held on by two tabs at the top. With the bottom piece gone, the side parts swing off easily. Don't worry about keeping track of which sides the silver trim pieces go on, as they're designed to fit on only one side (you'll see the cutout for the shaver head stem is off to one side).
3) The case is held together by 4 small torq screws. Use a torq screwdriver--do not attempt to do this with anything else. Be careful to turn the screws slowly, so you don't strip them.
4) With the screws removed, the two halves of the shaver will come apart. The remaining parts can be extracted without any special tools. Keep note of how they are removed, as assembly will be the reversal of removal.
5) Note that if you are replacing the batteries (there are two of them), you will need a soldering iron to detach them from the circuit board, unless you're replacing the whole part.
6) Reassembly is pretty much what you expect--the reverse of disassembly. However, the bottom cord socket part is tricky to get put into place. Pushing straight down on this part will not get it to go in, nor any other obvious way. It's best to get the prongs inserted on one side, then while pushing in on the prongs of the opposite side, apply pressure on the top side surfaces. The part should snap right back into place.
Oct 01, 2008 | Braun Syncro 7526 Electric Shaver
Changing battery..can't find
I took my izone 300 apart and replaced the battery with one purchased from Digiplant on Ebay for $9.98, shipping included. The battery is a Lithium Polymer 3.7 volt, 280 Mah, but I used a 3.7 volt, 550 Mah. It improves the battery life immensly and the flash never fails like it did on occasion when it was new. Hope this helps everyone looking for a replacement battery.
Apr 30, 2008 | Polaroid iZone 300 Digital Camera
Replacing the drive unit
Replace the drive unit yourself it is easy
Buy the drive unit $25:
http://shaveroutlet.com/braun-other-parts-c-4_27.html
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace drive unit
7) Reasemble
Jan 26, 2008 | Braun Syncro 7526 Electric Shaver
Hit Thomas and Friends TrackMaster R/C - Percy Logo
2,420 people viewed this question
Top Hit Toys Experts
ray gallant
Are you a Hit Toy Expert? Answer questions, earn points and help others
