Question about Sub-Zero 690 Side by Side Refrigerator
Ice maker not making Ice Cubes. The freezer is working. We shut off the main water supply to our house for two months. My model # is 532. This site would not accept that model number.
  • Sub-Zero Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Apr 25, 2010
Icemaker not working
In order to keep your refrigerator's ice maker working properly, there are some components that will require routine maintenance and inspection. Some of the most common problems that can occur with your ice maker are the ice maker not making any ice, making too much ice and not shutting off, the ice tasting bad, ice cubes too small or discolored and ice cubes not ejecting from the ice maker. Checking your ice maker for potential problems on a regular basis will keep it operating efficiently.
1.Inspect the water supply line for any signs of cracking or crimps in the line. A pinched water supply line can keep the water from getting to the ice maker, resulting in no ice or smaller than desired ice cubes. Check to verify that the water supply valve is open enough to provide an adequate supply of water to the ice maker.
2. Flush out the water supply lines if you are noticing a bad taste in the ice cubes. This can be done by disconnecting the lines and running hot water through them. Turn on the hot water at the kitchen sink and place one end of the water supply line near the tap, holding it in place to allow hot water to run through it. Place the other end of the supply line in the sink to allow the water to drain through.
3 Reattach the water supply lines to the water supply and refrigerator. Repeat step 2 for the water inlet hose which runs from the inlet valve to the ice maker. If the water supply lines are old or discolored, consider replacing them with new water supply lines.
4 Check the temperature in your freezer to verify that it is getting cold enough. The freezer's temperature should be at 5 degrees and can be set with a control dial, normally located in the refrigerator compartment of your appliance. To test the freezer's temperature, place a cup of cooking oil in the freezer with a cooking thermometer sitting in the cooking oil. Allow the oil to sit in the freezer for 2 hours and then check the temperature.
5 Check the ice maker's shutoff arm to verify that it is operating properly. To work normally, the shutoff arm should be in the lowered position. Inspect the arm for anything blocking it or preventing the arm from moving freely. Lift the arm up to see if the unit shuts off in the up position.
6 Unplug the refrigerator from the electrical outlet and remove the faceplate of the ice maker's shutoff switch with a screwdriver, located on the ice maker. Remove the entire ice maker unit from the freezer by undoing the screws that are holding it in place. Unplug the ice maker from the freezer and take it out of the freezer to work on.
7 Remove the mounting plate on the top of the ice maker by unscrewing the screws and lifting it off the unit. Locate the shutoff switch, which has three electrical wires attached to it. The shutoff switch is located directly under the shutoff arm of the ice maker. Pull the electrical wires off of the shutoff switch with needle-nose pliers and label them so you know how to put them back correctly.
8 Inspect the electrical terminals for any rust or corrosion. Use an electrical testing meter to verify that the shutoff switch is working properly. You should get a reading of 0 or infinity on the meter. If the shutoff switch is not giving a reading, replace it with a new switch and reattach the electrical wires to the switch.
9 Place the mounting plate back over the ice maker and attach it with screws, then reattach the entire ice maker unit to the freezer. Plug the ice maker wiring back into the freezer and put the face plate back over the front of the ice maker.
10 Plug the refrigerator back into the electrical outlet and allow the refrigerator to run for a couple hours. Inspect the ice maker to verify that it is working properly.
Hope this tips would help you.
Good day! : )
Sep 06, 2011 | Refrigerators
My icemaker on LG refrigerator is making very few ice cubes
If the ice maker is producing ice poorly, making small cubes or too few cubes then it means your ice maker is probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that is not cycling properly.
First, check the water line that's attached to the back of the refrigerator. Make sure it is having a good water flow. If the flow is poor, that means you will have to, repair, clean, or replace the tubing or the shut-off valve that supplies the water in the ice maker.
Second, check the water-inlet valve. You will need to replace the water inlet valve if it has failed.
Third, check the freezer temperature. It should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Lastly, check the ice maker mold thermostat. Make sure that it's cycling properly.
The above is what you need to check on........
I hope this helps....
Take care.
Mar 08, 2011 | Delfield Reach-In 6025X-LG Refrigerator
My icemaker for the LG French Door/Bottom Freezer Model # 25770SW is making very little ice.
Take care.
Mar 08, 2011 | Refrigerators
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Jul 08, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Whirlpool ice dispenser not working, but water is
There are three common problems with icemakers:
There's no ice
Small or too few ice cubes
Specks in the cubes
Note: If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Apr 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker will not work
Apr 01, 2009 | Frigidaire Optional Icemaker Kit
I have a GE Profile refrigerator the does not produce ice cubes
the fill tube that runs water into icemaker has most likely frozen up use a hair dryer and heat the tube up until the ice melts out then it should start up agian. you may have to remove the icemaker to gain full access to the fill tube. good luck peyton
Jan 24, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
334 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
