Question about Honeywell Programmable Thermostat Heater
I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
  • Honeywell Master
  • 43,501 Answers
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
heatman101
Posted on Apr 25, 2010
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Tip
Honeywell RTH7500D Thermostat
This Honeywell thermostat is a good medium priced thermostat that will give you many bells and whistles at a very good price. The programming is very easy to do and of course the thermostat is very reliable also.
The installation of this thermostat is very easy and if you need help with the installation you can go here to see the complete installation guide.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2221ES.pdf
If you have lost your owners manual and need a copy of it you can go here
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2222ES.pdf
With the help of these .pdf files you can get all the information that you need to install and troubleshoot your RTH7500D thermostat.
If you are replacing a thermostat make sure that you turn off power to your heating or air conditioning system BEFORE you start removing any wires. Failure to do so could cause you to burn out the 24v transformer of your system. Also make sure to mark all wires well before removal so that you know which wire went where and so that you can reinstall the old thermostat as it was if something goes wrong with the new installation.
For heat pump systems you WILL have to make some programming changes to the thermostat to get it to work with a heat pump system. Most all thermostats come programmed for conventional systems. This reprogramming is not difficult but is required for proper operation.
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3892721-programmable_honeywell
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
on Jan 16, 2010 | Heating & Cooling
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Amana PGD60C1152E no heat
Your thermostat Function 0170 must be set to "1" for Single Stage Heat/Cool. Function 0180 must be set for "0" for Heating Fan Control. Function 0240 must be set for "5" for the Heating Cycle Rate for your <90% Gas Furnace. If you have already done these steps or if, after doing these steps, you continue to experience a problem, you problem could be with your Gas Furnace. I'm including some links for information on your system and thermostat that include wiring diagrams.
http://johnstonesupply9.com/TechDocs/Amana/Package%20Units%20Gas-Electric/PGD%20Pkg%20Gas%20Ele/PGD%20Tech%20Info.pdf
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Mar 06, 2010 | Amana Haier AP125HD Air Conditioner
Heat PumP: Rheem Two Stage Heat, One Stage Cool Thermostat Replac
R = R with jumper to RC hot side of transformer
B = Reversing valve
Y = Compressor relay
G =Blower
C = common on transformer (X on old t'stat)
W2 = Auxillary heat
E = Emergency heat
Mar 04, 2010 | Heating & Cooling
No heat after installing honeywell thermostat H8110U
hook up the blue wire in the furnace cabinet where the blower section and the other thermostat wires are connected to the furnace. the thermostat you have uses a common wire from the thermostat to the furnace and this needs to be hooked up in the furnace otherwise you will have the problem you are having.
Dec 07, 2009 | Honeywell Electronic Programmable...
One honeywell to another
you need to program the thermostat for the reversing valve "O" it will tell you how to do this in the manual. you will need to chang from "O" to "B" or "B" to "O" depending on how its set.
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Changing out old thermostat
your old thermostat is a milivolt and the wire runs from the heater to the thermostat. You have to open the back of the new one and connect the wire as per the instructions on the wireing diagram that came with the new one. I just installed a similar one myself, you will be very happy with it.
Jan 24, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
584 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
