Question about Sonance The Sub Subwoofer
Power won't come on for my Sonance Sub Woofer.
Power won't come on . Could it be a fuse?
  • 22 Answers
Yes, and sometines the power wires get broken inside..... good luck
Posted on Apr 25, 2010
Sub woofer not turning on
Is it receiving power? If not that is your answer - could be a blown fuse, bad wire, bad connection, etc.
If power is there and it still does not work then the problem coud be with a bad sub woofer on/off switch, internal fuse, or worse, blown amp from over driving.
Feb 25, 2016 | Boston Acoustics MCS 90 Horizon Series...
Controler and sub woofer no power
This previous diagnostic, isn't good, if you test and no continuity between the positive and negative terminals generally means a blown sub.
You won't always get scratching or distortion from a blown sub. Sometimes the voice coil just overheats and burns out like a fuse. In this case there will be no sound at all from the sub, because no power can flow through the voice coil. A continuity test between the positive and negative terminals will show no connection.
Hope this helps.
Jul 05, 2011 | Audio Players & Recorders
The rca jacks for my sonance the sub subwoofer are apparently broken or loose inside. How do I get the back off to repair?
Hi
Please check this link for your problem:-
http://www.instructables.com/community/Removing-Broken-Pin-from-an-RCA-Jack/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 18, 2011 | Sonance The Sub Subwoofer
Is sonance the sub, 12 inch subwoofer 4 0hms are 8 ohms ?
Why does it matter? Being self-powered, it presents a load only to its own amplifier.
Jan 17, 2011 | Sonance The Sub Subwoofer
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
Jun 05, 2010 | Car Audio & Video
Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Feb 15, 2010 | Harman Kardon HKTS 7 System
Fuse
the fuse in underneath the power cord, it pops out you an use a small screwdriver to remove it.
if you need a visual here it the link to your manual:
http://www.sonance.com/files/downloads/file/CabinetSubwooferManual_030509Final.pdf
just replace with same ampand size fuse and you should be GTG!
Cheers!
Feb 14, 2010 | Sonance The Sub Subwoofer
I have a Sonance "the Sub" and it is in perfect condition. But it will not come on. The power light is on. Is it worth it to fix it and what could be the problem.
Yeah, it's worth it. What have you tried to get it to work? Feed it some line level input from something and observe what it does.
Jan 19, 2010 | Sonance The Sub Subwoofer
Need to repair my HKTS 14 Harman Kardon Subwoofer
Since this is a power sub woofer, it may have an amplifier problem that would require professional service. Yoiu can start by checking the fuse. Make sure the sub woofer is not plugged into the wall when you check it. Some of these powered sub woofers have the fuse right on the panel where the cord goes into. It may have a round cap and you turn it and pull the fuse out. If the fuse is blackend or you can see that the filiment inside the fuse it broken, you can replace the fuse with the same rating of fuse. The rating is on the metal tab at one end of the fuse or may also be listed right next to the cap for the fuse holder. If the fuse is not accesable from the panel, you need to remove panel and look for it where the power cord comes into the panel. It will be right in line with the power cord. The panel for most sub woofers are normally held on by screws all the way around the panel. You should only need to take the outside screws (around the edge of panel) off of the panel. The inside screws hold on the circuit boards, connectorsm and transformer.
If you had given more information about the problem with your sub woofer I could have given you a better answer, but with the limited information given all I can suggest right now is to check the fuse. That is always a good starting point. If you give me more information I may be able to help you much more, I have repaired many powered sub woofers but not this model. Most are very similar and can be checked with minimal effort. You would need to have a multimeter to check almost everything else with the sub woofer. Let me know if you have a multimeter and are willing to check it further. Anything less than a "FixYa!" rating is really not a good rating, so please do not rate this solution until we have had a chance to communicate more about the problem. That way I will not be given a bad rating when I have not had a chance to actually help you yet since I can not tell you how to fix your problem without more information.
Dave
Oct 14, 2008 | Audio Players & Recorders
Sonance The Sub Subwoofer Logo
128 people viewed this question
Top Sonance Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ASTEREY ELECTRONIC...
Level 1 Expert
Are you a Sonance Audio Player and Recorder Expert? Answer questions, earn points and help others
